Any 7.3.1cs4 issues with Expansion HD chassis?
Has anyone noticed any problems with running PT 7.3.1cs4 on a Mac Pro while using an Expansion HD chassis? I have not installed this update for fear of a problem with the Expansion HD. I have a fairly stable system now, and I don't want to screw that up, but if cs4 helps, then I would like to have it.
I'm running MacOS 10.4.8 on a Mac Pro 2 x 3 GHz dual-core Xeon, 1 GB RAM, PTHD 7.3.1, Expansion HD chassis, 1 Core, 1 Accel, 2 HD Process cards. Thanks, Tom
Hit or Myth Productions |
Re: Any 7.3.1cs4 issues with Expansion HD chassis?
Hi
I have a similar system to yours but the computers a g5 dual 2.5PPC on OSX 10.4.9 with 2gig ram. However i'm running 7.3.1cs4 with the Expansin HD chassis and identical cards with no major problems other than the documented hiccups on this forum (such as the occassional type input problem). This system is in use everyday with live band recording scenarios and is reasonably stable. Hope this helps. |
Just installed my Digi HD chassis today. Running 7.3.1 cs4 on a Mac Pro with 2 video display cards (20" cinema on my ICON and 3 42" plasmas) HD3 accell in the chassis. No problems yet. It is suggested you reduce your HW buffer size by 50% IE 512 down to 256 or 256 to 128 but I'm sure you already knew that.
What I'm curious about is can you run UAD cards in the chassis? I know the Digi "Company line" is NO but in reality will it work and be stable? I have posted a thread on this very question with only one response. Any info would be greatly appreiated. I'll keep you posted on how the chassis cs4 thng turns out. Thanks!
Madness does not always scream at you... sometimes it's the quiet voice in your head that asks "Hey is there room in there for one more?" HDX 10.1 (2 Cards) Mac Pro 8 Core 2.4Ghz Westmere 26 gig Ram Icon D-Control, Two 192HD 16x16 analog and 8x8x8 Avid Mojo, Sync HDI/O |
I tried in the magma before and it was overwhelming the system
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1 - D-command 24- Trinnov Dmon6 |
Issues with expansion/HD chassis- latency and altiverb TDM... | smokeydan | Pro Tools TDM Systems (Mac) | 1 | 05-05-2010 03:59 PM |
some Digi HD Expansion Chassis Issues | minister | Pro Tools TDM Systems (Mac) | 34 | 02-12-2007 01:33 PM |
Issues with expansion chassis not recognized | GoButtonGuy | Pro Tools TDM Systems (Mac) | 2 | 01-05-2007 03:52 AM |
Expansion chassis and latency issues with VI's ?? | edhamilton | Pro Tools TDM Systems (Mac) | 1 | 07-13-2006 11:40 PM |
Are all expansion chassis created equal regarding -6042 issues? | Lee Blaske | Pro Tools TDM Systems (Mac) | 5 | 08-21-2001 05:07 PM |
