Old 11-01-2008, 10:05 AM
allanvee allanvee is offline
Default Some partition hard drive are invisible on Structure,
I just bought Structure Full version and I have a curious issue:
All my patchs are on external hard drive.
This hard drive is partitioned. The partition where the Structure patchs are located is visible in the browsher menu but the 4 other partition are invisible.
I've got an other external drive (same brand, same capacity) and the totality of the partition of this disk are visible.
Anyone have an idea to repaired this issue?http://duc.digidesign.com/images/smilies/confused.gif
Thank you
Alain
Old 11-01-2008, 11:15 AM
Default Re: Some partition hard drive are invisible on Structure,
In the Browser Page Alain is the File Type All button highlighted?
filosofem
Old 11-01-2008, 01:45 PM
Yes absolutly.
It's very curious, I have already check the authaurization of each partition concerning writting and reading mode with no result.
I don't understand.
Old 11-01-2008, 02:14 PM
Hmmm... are you able to 'Point' Structure to those missing drives using the Setup>Content page, Alain?
filosofem
Old 11-02-2008, 11:11 AM
In the "content window" I have the same problem:
When I looking for the partition of my hard drive I see only one (on five) partition where the patch of structure are located.
The other partition are invisible consequently it's impossible to point my partition.
I try to lauch the hard drive utility for check and repair the drive authorization. (I've got on mac G5 2 2Gh ). No result.
I'm afraid that the problem must be more serious...
May be an error when I partionned this hard drive like format (HFS+) or something like that...
Old 11-02-2008, 05:13 PM
Hmmm... I'm on PC so I not going to be much more help sorry Alain, you could try if you haven't done so already is work your way through the General Troubleshooting Tips, I think there might be a partition tip.
Regards and best.
filosofem
Old 11-02-2008, 05:36 PM
I'm curious if the drive is partitioned GUID (New format) or MFT/DOS Format (Old format)
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
Old 11-03-2008, 01:07 PM
Wouahou!!
That's a very technical question, I don't know how to acces at this information??..
If I check my partition with the command (CM+I) in the driver utility I obtain : Partition type Apple_HFS not anymore.
I've got an other disk (exactly the same) beside partitioned with the same protocole and I can se all partition of this hard drive.
Actually the "help support" Digidesign can't help me..
I already try different process without sucess..
Invisible hard drive woodenfeather macOS 8 08-07-2011 03:23 PM
Partition Hard Drive? Clean out G$ hard drive? ike805 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-23-2006 10:23 PM
partition hard drive slicvic1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-01-2005 08:06 PM
How to partition the hard drive on my new PC? rossscarbro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-21-2004 08:53 PM
new g4 733, partition hard drive? RDunn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2002 02:14 PM
