Old 09-20-2022, 01:00 PM
Ben Jenssen's Avatar
Default Re: Eucontrol 2022.9 Crash
EUCON 4.8.6.78
EuControl 2022.4.0.78
I haven't read all the details of this thread, but I thought I'd just chime in.
I'm using SSL Native Channelstrip on most all tracks in all sessions. I move these plugins around from time to time, but it never crashes EuControl. It's been stable for a long time.
I've seen one thing, though; I often have the same session open in the background, for days sometimes. And then one day, one of two things often happen; I come to the session, and as I press play I get 'error, playback failed, please increase AAE memory'. Solution is simple; I close and reopen the session and everything is fine. (I've not seen this happen since I set the disk cache to 'Normal', we'll see how that goes. I was thinking memory build up of some sort, but ActMon says no problem, BTW.)
The second thing that can happen is that PT is working fine, but Eucontrol is not, and opt-cmd-esc says Eucontrol 'not responding'. I force quit and launch again and all is well.
Old 09-20-2022, 02:32 PM
Iain Haworth's Avatar
Iain Haworth Iain Haworth is offline
Originally Posted by Mirko Cascio View Post
HI, Iain,
I have actually tried only plugins from the SSL bundle that have this problem.
I have tried other brands, like, msdsp, fabfilter etc etc .... and it seems to be ok.
Thank you
I installed the SSL bundle and still was not able to reproduce the crashes you're seeing. Could you send me logs from EuControl (click on EuControl icon at the top right then select "Collect Support Files")?
It would be great to get your Custom Knob Maps too which is a little trickier to find (~/Library/Preferences/Avid/Consoles/KnobMaps). I can send you more detailed directions directly if needed
Iain
Old 09-21-2022, 09:00 AM
Mirko Cascio Mirko Cascio is offline
Originally Posted by Ben Jenssen View Post
EUCON 4.8.6.78
Hi Ben,
I use eucontrol 2022.9. in fact, pro toools doesn't crash, just eucontrol.
Thank you
Mirko
Old 09-21-2022, 09:12 AM
Iain
Hi Iain,
I try to attach the files but it tells me they are invalid
Thank you.
Mirko
Old 09-21-2022, 10:38 AM
BScout BScout is offline
Hi Iain,
Thank you.
Mirko
You can't share them here on the forums.
You need to put them on a shared service (dropbox, icloud, g-drive, etc.) and then send the link to the files by private messaging or email (click on his name and you'll see those options)
  #16
Old 09-21-2022, 11:27 PM
Ok thanks
I do it right away
Mirko
2022 Crash Behaviour in Windows. Anyone? lesbrunn Pro Tools 10 08-17-2022 02:23 PM
Artist Transport and EuControl 2022.4: different issues Megalobass Artist Series 1 06-12-2022 06:37 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
EUCONTROL 3.0.1 Crash continuously on 10.8.4 & 5 tizi66 Artist Series 2 01-03-2014 04:25 AM
eucontrol crash Mexadon Artist Series 0 02-13-2013 12:21 PM
