Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 03-30-2022, 02:40 AM
kol12 kol12 is offline
Default Where should I/can I install Pro Tools First?
Hello,
I'm just wondering if Pro Tools should ideally be installed on it's own dedicated drive and OS? I have my main Windows 11 desktop PC that I use for dedicated GPU gaming, web browsing and other work with various apps installed. I wonder if for optimal performance of Pro Tools if it should run separately from my everyday OS?
My second question is could I install Pro Tools to a new user account on my current Windows 11 installation or would a dual boot OS be better?
Old 03-30-2022, 05:45 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Where should I/can I install Pro Tools First?
Personally, I think you're over thinking it :)
Just install it on your C: in your normal user account. If you don't have an NVME or at least a SSD as your C: drive, then you might want to save your sessions and samples on a separate drive.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 10 Pro
Pro Tools 2021 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 03-30-2022, 02:46 PM
Joel
Can sessions and samples be stored on another drive other than C: anyway? I prefer to keep my C: as lean as possible as it reduces the size of the backup images I take of C: drive...
Old 03-30-2022, 03:27 PM
JoelG's Avatar
I haven't used First a whole lot, but yes you should be able to change the location of the cache folder: https://avid.secure.force.com/pkb/ar...t-files-stored
Joel
Jam Space:
Home:
Rig:
Old 03-31-2022, 01:49 AM
Joel
What is generally the most storage consuming when working with Pro Tools?
Old 03-31-2022, 06:23 AM
JoelG's Avatar
I'm not sure if this is what you mean, but the recorded audio files you make will be what takes up the most space. That and/or samples, if you use them.
The cache folder I referenced is where all your recorded audio will be saved when you're working in Pro Tools First.
Joel
Jam Space:
Home:
Rig:
Old 04-01-2022, 12:50 PM
Pro Tools software installs to the C: drive, only. Sessions can go on any drive that meets the requirements for speed. If you have a USB-C or USB-3 port, an external case with that connection should be fine as long as the drive inside the case is an SSD or a 7200 RPM spinner. Samsung T7(external) gets great reviews from several Pro Tools users here. Thunderbolt would be even better if you have the option.
Old 04-02-2022, 05:01 AM
Is it common to have a dedicated storage drive for sessions/samples? Do plugins use much space or is it the samples associated with the plugins that do?
Old 04-02-2022, 03:25 PM
Re plugins; Plugins that use sample libraries can be huge(the plugin is small, but the library is huge). When possible, locate the sample libraries on a separate drive. Processing plugins(like EQ, Reverb, compressors, etc) take up very little space on your C: drive(example; my plugins folder is 9GB on the C: drive, but my samples fill a 2TB drive)
Re sessions being on their own drive; yes its a good idea, BUT, if your C: drive is a good SSD with lots of available space, sessions can run fine from the C: drive(this advise is from the days of spinning hard drives). I keep things separate so I can back things up more easily(and you do need to back everything up if you would be upset if it disappeared).
So, the ideal setup would be this:
Drive 1(C:)-for OS and plugins. Use a good SSD(some say 250GB is enough. I say 500GB is minimum).
Drive 2-for sample libraries. Use a good internal SSD, 7200 rpm spinner is second choice. Use enough capacity to cover your needs now, but times 2(for future expansion)
Drive 3-for sessions. Use a good internal SSD, 7200 rpm spinner is second choice. 1TB is a good minimum.
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 05:39 PM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 08:23 AM
Can't install Pro Tools 8! Clean install, new system, Vista! DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 01-09-2011 12:16 PM
Can't install Pro Tools LE - Insert disc but no option to install Paul McConnell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-22-2010 09:13 AM
Why install Pro-Tools to install drivers for Mbox2 bigbobbysd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-23-2010 08:42 AM
