Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 06-08-2014, 07:12 PM
Xozz Xozz is offline
Default HD omni preamp inputs
Hi guys,
Trying to set up the mic inputs on the HD omni preamp for the first time, and I'm running into a bit of a problem. When I'm in protools I'm not able to add those two channels in the i/o setup. The line-in inputs show up fine, but nothing for the two preamp inputs. And, when i click on the mic preamps tab in the i/o menu, nothing shows up, and there aren't any options.
I've gone into the peripheral menu as well, to the mic preamps tab, and while I see PRE from the dropdown box, the only send and receive options I see are MIDI. All I'm looking to do is hook up a single mic through the omni's preamp,don't know why it's causing so much trouble. Was curious if there were any glaring mistakes I'm making. Thanks!
Old 06-09-2014, 05:53 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: HD omni preamp inputs
Hi.
The Omni preamps doesn't show up in the Mic Preamps tab.
They show up in the Input tab under Analog 1-4.
You control the preamps with the rotary knob Preamps on the front side of Omni. Push it to select wich preamps you want to adjust. Then click on the Mic/Line/Inst button to select what you want to use.
If you plugin a mic directly into the preamp you have to select the Mic setting. Then adjust the rotary knob to set level you want for your mic. Remember also to push the 48V button if you have a mic that requires phantom power.
If they don't show up as inputs in Pro Tools try pushing the Default button both in the Input tab and then the same in the Bus tab.
Old 06-09-2014, 07:27 AM
nst7 nst7 is offline
Xozz, the "Mic Preamps" tab in the I/O setup is only for the 8 channel Avid/Digi "Pre" model. Even though it shows a picture of the Omni or other interface.
That preamp model is the only one that can be controlled from within Protools.
As Crisdee mentioned, the mic preamps will just show up as inputs 1-2, and you select mic, line, or instrument on the unit itself.
Old 06-09-2014, 11:02 AM
Bill Denton Bill Denton is offline
Not quite correct...That is the only Avid preamp that can be controlled from within Pro Tools.
But Millennia and a couple of other companies offer preamps with this capability..
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Omni Preamp fix? diamondschwin Pro Tools HDX & HD Native Systems (Mac) 43 08-03-2016 10:01 PM
OMNI Preamp issue... JR Fountain Pro Tools HDX & HD Native Systems (Mac) 21 05-18-2012 07:41 AM
OMNI Preamp gain stargazer Pro Tools HDX & HD Native Systems (Mac) 4 05-17-2012 12:43 PM
Omni Preamp? DetroitT Pro Tools HDX & HD Native Systems (Mac) 2 01-11-2012 04:58 AM
OMNI preamp impedance? Mr.Scarbee Pro Tools HDX & HD Native Systems (Mac) 0 08-09-2011 04:19 AM
