Old 07-29-2009, 04:56 PM
brokenandallen brokenandallen is offline
Smile Reason Not Showing Up as Plug
Hello,
I'm running pt le 7.4 on a G5 dual 1.8 PPC os10.4.9. After upgrading to 7.4, reason will no longer show up in my list of available plug ins. I've tried to find out if it is a compatabilty issue, but i haven't found anything. (Is 2.5 no longer compatible with 7.4?) Reason was installed after upgrading to 7.4. Any suggestions would be great...
Thanks in advance....
Old 07-30-2009, 01:29 AM
The Dougfather The Dougfather is offline
Default Re: Reason Not Showing Up as Plug
You have to launch Reason once in standalone mode before it will show in Pro Tools, try it.
Apparently certain components are installed on first launch.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 07-30-2009, 08:31 AM
djmichael.london djmichael.london is offline
I thought u had to be at least 3.0.5 or higher.
MichaeLondon
Mac : IMac 3.0 ghz/OSX 10.6.8/Mbox Mini/PT 7.4.2
DAW : Pro Tools 7.4.2 - Mbox Mini
www.myspace.com/michaelondon
Old 07-30-2009, 09:27 AM
You need 3.0.5 for intel macs, whether there is a general compatibility issue with 2.5 i can't comment.
iCON Photography
Old 07-30-2009, 07:40 PM
I run reason in standalone all the time utilizing the 002 and digicore audio. It still never shows up in protools. They tell me Reason 4 is compatable with my system, do you think that 2.5 maybe the issue?
Thanks
Old 07-31-2009, 08:32 AM
definitley, here is the compatibilty for adapted but I believe its tha same for full version.
Propellerhead SoftwareReason Adapted3.04 (W)
3.05 (M)3.04 (W)
3.05 (M)3.04 (W)
3.05 (M)
MichaeLondon
Old 07-31-2009, 08:34 AM
These are all for 7.1 and up in Pro Tools
MichaeLondon
Reason Not showing Up Under Plug Ins steadward 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-21-2011 04:33 PM
Reason 3.05 not showing up in plug-in folder illyaas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-24-2007 12:31 PM
using P.T 7.3, reason is not showing up as a plug-in??? tomward Pro Tools M-Powered (Mac) 3 03-13-2007 03:52 PM
using P.T 7.3, reason is not showing up as a plug-in??? tomward Pro Tools M-Powered (Mac) 0 03-13-2007 06:45 AM
Reason plug-in not showing up?? weird.... dougied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-12-2007 08:13 AM
