Old 05-22-2024, 01:43 PM
teacherman teacherman is offline
Default Issue when Importing a .MOV file.
I'm trying to import a video that I took with my iPhone 12.
When Importing the .MOV file into Protools, both audio and video are scrambled: audio track becomes basically some form of white noise and the video track is smeared/blurry looking.
My PT Session is at 44.1 /16Bit.
Your support, please.
thank you.
MacBook Pro 2017; 16GB Ram; Protools 2024.3; OS. 12.3.1
Old 05-22-2024, 01:56 PM
infohou infohou is offline
Default Re: Issue when Importing a .MOV file.
thank you.
Possibly a codec like HEVC or HEIC that Pro Tools doesn't like. Try opening the file in Invisor or something that will tell you what codec and format the file is in. You may need to convert it.
Remember MOV is a container that is capable of handling several codecs.
Hope that helps,
Robert
Robert A. Ober
IT Consultant, Vidcaster, & Freelance Preditor(Producer/Editor)
www.infohou.com
Houston, TX
Old 05-22-2024, 02:57 PM
audiolex1 audiolex1 is online now
thank you.
Get Shutter Encoder, its free. Convert the movie to a different codec like H264 and PCM audio.
Then import it.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 05-22-2024, 03:23 PM
Then import it.
Depends on what platform to which he is delivering. H.264 will probably lower the quality. For instance if he is fixing audio then going to Media Composer then he may want to go with DNXHD.
Y'all take care,
Robert
Robert A. Ober
www.infohou.com
Houston, TX
Old 05-22-2024, 04:18 PM
Eric Lambert's Avatar
From an iPhone 12 I'd guess that the format is HEVC and I'm not surprised that PT won't import it directly.
As mentioned above, get Shutter Encoder. You should have that anyway because... well, everyone should have that Swiss Army knife. Made by people who work in the business who constantly update and improve it.
Old 05-22-2024, 04:23 PM
It would, but perhaps only slightly. And if it's a situation where you ultimately only want to alter the audio you could strip the original audio out of the original .mov file and replace it with the new audio. Video would remain intact.
Old 05-22-2024, 06:38 PM
Y'all take care,
Robert
That is actually not true. H264 doesn't mean lower quality. It means more compressed.
You can have H264 HD video as I get it all the time. It is just very CPU hungry as the decompression takes a lot of power.
And why Apple Silicon put in an H264/5 engine into the chip so it would leave the CPU alone.
I actually backup my shows from the DNX36 to H264 for space saving, roughly 15 gigs, and have re encoded it to DNX36 with no picture loss.
And if going into MC, it will likely convert it anyway.
Almost every plugin
Old 05-22-2024, 10:13 PM
We may be getting off-topic here, but I'm wondering if we'll see wider usage of HEVC (H.265) in place like ProTools. Because PT has had issues with H.264 files in the past (forcing the video engine offline, something that has plagued PT for years), I'm wondering if 265 might someday be an option.
As you suggested, it requires more computational power, and maybe that alone will keep it at a distance from PT for a while.
But I hope not. I've gotten tired of having to convert videos to DNxHD just so the video engine can stay in place. These converted files are WAY larger than they need to be.
Old 05-22-2024, 11:47 PM
BScout BScout is offline
As long as the AVE is not native on Macs, it can't take advantage of the coprocessor on M series chips to decode. That is also true for processing HEVC (h265) as much as the other codecs.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface ProS1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.7RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 05-23-2024, 10:10 AM
That's right, I'd forgotten that the engine isn't native. Odd, considering Avid is largely a video company.
Importing Audio file issue briaboy Pro Tools 10 5 04-09-2014 03:20 PM
Pro Tools file linking/importing issue. wreckthisplace macOS 14 11-13-2012 10:26 AM
Issue importing PT10 bounced stereo file into FCP Joshua Lopatin Pro Tools 10 6 07-10-2012 11:15 AM
Issue importing PT10 bounced stereo file into FCP Joshua Lopatin Post - Surround - Video 0 07-09-2012 09:16 AM
Issue with exporting/importing midi file...HELP!! jambirn Pro Tools TDM Systems (Mac) 2 07-28-2006 01:50 PM
