New i7 system sandra report , need help please..
What's up everyone,
First let me thank everyone here who has helped make this a very informative and invaluable place to trouble shoot digi software / hardware issues. I have been following here for years and just recently built an i7 machine for my 002 rack on protools 8.01 on XP service pack 3. I have been having some pretty rough times getting things to run stable. I so far have been suffering from the dreaded white noise bursts, the system crash's or hangs with certain plugins and i feel like overall performance should be better. I've had to reinstall protools several times, trash system preferences and etc. I have done the digi tweaks I'm running waves v7 mercury native Mcdsp Emerald bundle latest version (except mcdsp said to revert back 1 version for revolver) also my adat mic preamp (ada 8000) leaks into the master bus even without audio tracks being armed or even open, anyone ever have this happen? is this an i/o setting possibly? Does anyone see anything here on the sandra report that could be causing me these headaches ? Possibly the firewire card being an NEC chipset? SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : WORKGROUP Host Name : user-bc1a1a8551 User : studio Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Asus Rampage II Extreme BIOS : AMI 1504 07/23/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB DIMM DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 3.22GHz (6.43GHz) Chipset Model : Intel Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 3.22GHz (6.43GHz) Total Memory : 6GB DIMM DDR3 Memory Bus Speed : 2x 670MHz (1.34GHz) Memory Module(s) Memory Module : Mushkin 991585 996585 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : Mushkin 991585 996585 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : Mushkin 991585 996585 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Graphics Processor - right now using a generic vga driver per digi's suggestion but the card is a PNYORCE 9600 GSO 768MB DDR3 GRAPHICS CONTROLLER Storage Devices WDC WD5002ABYS-02B1B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) WDC WD2500SD-01KCC0 (250GB, SATA150, 3.5", 7200rpm, 8MB Cache) : 233GB (E:) ATAPI DVD A DH16A3L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 466GB (NTFS) @ WDC WD5002ABYS-02B1B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Storage (E:) : 233GB (NTFS) @ WDC WD2500SD-01KCC0 (250GB, SATA150, 3.5", 7200rpm, 8MB Cache) Optical Drive (D:) : N/A @ ATAPI DVD A DH16A3L (SATA150, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13h Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : NEC uPD72874 IEEE1394 OHCI 1.1 3-port PHY-Link Ctrlr FireWire/1394 Controller 2 : ASUS VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Wireless LAN PCI 802.11 b/g adapter WN5301A - Packet Scheduler Miniport (Ethernet, 54Mbps) Wireless Adapter 1 : Wireless LAN PCI 802.11 b/g adapter WN5301A - Packet Scheduler Miniport (802.11g (ERP), 54Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 Thanks in advance! |
Re: New i7 system sandra report , need help please..
The firewire card not having the approved TI chipset could certainly be a bottleneck. SIIG cards seem to ALWAYS have the Ti chip on them.
Also, most would prompt you to disable the wireless features, at least while PT is running. I have an ADA8000 and have never experienced that problem you're speaking of. Wondering if it could be bad grounding or cheap TOSLINKs? Connected both ways? You really only need ADA out to 002r in. |
Cool,
yes i always disable the wireless, but had to enable it to post .... Im gonna try to change the toslinks out for new ones..I have to find a texas instrument firewire card... |
And again, just a toslink from the ada out to the digi in should do.
right on.... anyone else see anything that could be an issue with my setup / config ?
thanks... |
Hey dawnofadream,,,,,,,,,,,,, A lot of us like a Hard drive with 32MB cache! All of mine are, and I no of a few others that feel especialy for your audio drive, that something like the WD Caviar Black, 7200 rpm, and 32 MB cache is a very good choice. I would leave your system drive alone for now, and maybe try a WD for your audio!! They are not to expensive, and could do a lot better than the 8MB cache your using!!??
Good Luck ,,, keep us posted ,,,,,,,,,,,,, Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
i know shoot me ! That drive was supposed to be for the system and the 500 gig 16 mb cache for audio, but the knucklehead who installed xp did that! i dont own a copy of xp myself, i had the store install it for me. So i have not been able to change it... luckily.. I have a glyph gt050q 250 gig external firewire 400/800 and esata drive that i just setup to use.... hopefully this will be good !
alrighty, so i ordered a siib texas instruments firewire card to replace my nec chipset...
did the dverb test tonight was hitting 290 dverb 2.0's @ 1024 buffer not to bad... not overclocked at all... i think i may leave it as is to, as long as it's stable! lol what do you guys think ? ps - the adat leaking through the master bus only happens when the I/o paths default to stereo pairs. VERY ODD, when i hit default and it assigned each input to mono again, it went away, I also checked the cables ( they were fine) |
Sandra Report System Check Compatibility for Windows 7 | joshphb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-18-2013 04:59 PM |
I need a system evaluation ...Sandra report included | Kempo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-13-2010 12:51 PM |
Here is my Sandra Report.... | MCallan713 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 03-17-2010 08:39 PM |
PUH-Lease Help Me With My System. Sandra Report Included This Time. Going MAD! | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 02-10-2010 04:17 PM |
Thanks! Sandra Report | stevegrisham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-08-2009 09:26 AM |
