usb midi keyboard setup?
Can anyone point me to a link ( or tell me here) explaining setup of a USB midi keyboard within PT6.4 LE? I have an Oxygen8 keyboard I want to use to trigger SampleTank, but can't seem to get it to work. Any help is appreciated
Tony Powerbook 1.5ghz G4 Digi002R PT6.4LE |
Re: usb midi keyboard setup?
Just use the USB cable and go to the midi setup and hook the arrows together out to in, in to out
Do you see the Oxygen 8 in the Apple MIDI Setup? It should automatically show up once you've plugged it in.
Open a new PT file. Add a stereo Aux and 1 MIDI track On the stereo Aux, insert Sampletank. On the MIDI track, under output, you should be able to select Sampletank Channel 1. Press the R record button on the MIDI track. You should now be able to hear the Sampletank.
Regards, Ned Monkey Boy Studios 2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3 Plugins, Virtual Instruments, and real ones |
I have done all the correct (I think) steps with creating channels and inserting Sampletank and assigning inputs and outputs, but the keyboard doesn't trigger anything. I will look into the Apple midi setup to see if that helps. I was wondering if there is a setup step outside of Pro tools that is needed for the keyboard to be recognized. When I do "rescan midi" in the setup box in PT, it doesn't find the Oxygen8. All drivers are installed.
I'm also new to Mac. Is the Apple midi setup within PT, or a Mac utility? Thanks Tony |
First time midi keyboard setup help | Jaimie | Windows | 1 | 08-31-2013 07:10 AM |
Midi keyboard setup not working? | Raoul23 | MIDI | 0 | 05-27-2011 08:18 AM |
Midi keyboard Setup, help needed! | Darkostica | MIDI | 12 | 05-27-2010 06:05 PM |
Midi keyboard setup.. | Nesp | MIDI | 5 | 02-24-2010 08:57 AM |
Setup MIDI keyboard | swwazz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 10-29-2004 05:58 PM |
