Old 06-28-2007, 01:07 PM
absolutpregones absolutpregones is offline
Default Latency problem
I would like to know how to reduce latency on recording with the 003 rack. We already set the buffer size to 128 samples and all the other options in the playback engine menu. We have a PPC G5 dual 1.8 with 1 GB of ram. If anyone has a solution......
Old 06-28-2007, 01:19 PM
frienddragon frienddragon is offline
Default Re: Latency problem
monitor the track being recorded at the source BEFORE it goes to Pro Tools, otherwise you're SOL. If you are using the 003 mic pres - uh - well that might not work, but if you are using an outboard mic pre split the signal out to something like a Mackie and create a monitor mix there instead of the 003.
Recording Engineer, KU School of Music
Owner, Two Tigers Audio/Video
Pro Tools LE, MBox, Apogee AD-16X, Rosetta 800, Logic 9, MacBook Pro, Symphony Mobile System
Old 06-28-2007, 05:21 PM
tele_player tele_player is offline
I assume (incorrectly?) that the 003 has the same Low Latency Monitoring feature as the 002. This is DSP-assisted monitoring in the interface itself, and delivers lower latency than the lowest buffer setting. Only gotcha is that plugins on the record-enabled tracks aren't enabled during recording.
Low latency monitoring is enabled somewhere in ProTools, there's not button or switch on the interface for it.
Quad 2.5 G5, 4.5G RAM
Latency problem... alfaholic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-15-2009 08:47 AM
DPC Latency Problem? paulrgmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 02-17-2009 01:11 AM
latency problem mug 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 09-24-2008 09:21 AM
Is this a latency problem? jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-13-2002 12:46 AM
latency problem geojack62 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-03-2001 12:12 AM
