Amplitube Automation!?!
Hi, I'm running a big session at the mo and I have Amplitube LE on one of the tracks.
I've automated the Master Bypass (On/Off) of the Amplitube LE plug-in but it doesn't actually do anything on playback. I've tried it with the plug-in open, closed, starting On, starting Off, with that track soloed and with all tracks running and the Master Bypass button seems to react to the automation, and the Amplitube icon on the insert section of the mixer goes dark blue (as plug-ins do when bypassed) but the sound remains unaffected, it either stays on or stays off, seeming to totaly ignore my automation. It's really starting to bug me as it's slowing me down now. Is there some obvious thing I'm overlooking? Any advice would be great, thanks! Ben Powerbook G4 1.5 GHz, 2 GB RAM, PT 7.1, 002R, Lacie 160GB FW800 HDD ...Come on People!?!? Anyone?? Someone out there must know what the problem is or had similar issues??...
Studio - MacPro 2x2.66 GHz, 4GB RAM, PT HD 8.0.4, 96i/o + ADAT, Mackie 24-8 desk, much outboard and 3rd party stuff Mobile - MacBook Pro 2.6 GHz, 4GB RAM, PT v7.3.1, 002R, 003R, MBox + 3rd party stuff |
Re: Amplitube Automation!?!
I tried a quick experiment with that plug and it worked fine. Did you check if the track automation is set to 'read' or off?
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
also, you said you enabled the master bypass on the plug...is the word bypass now colored green? If not, its not enabled. also, something else to try, on the track, can you view the bypass automation envelope? try holding control+apple and click the bypass button on the plug. this should switch the track view in the edit window to show the bypass envelope instead of the waveform. if it doesn't, you may not have everything enabled correctly
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
Help-Amplitube automation | Spliff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-13-2021 12:52 PM |
Amplitube + automation | Carl Kolchak | Pro Tools 10 | 8 | 11-16-2013 07:36 AM |
MIDI Automation to Audio Track Automation | BBKBB | Pro Tools 10 | 6 | 11-28-2012 01:56 PM |
Protools Automation to AAF Media Composer Automation | TommyT | Pro Tools TDM Systems (Mac) | 1 | 08-10-2011 01:40 AM |
Convert MIDI automation to audio automation | jnash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-21-2010 03:28 PM |
