Old 03-07-2011, 07:47 AM
poly915 poly915 is offline
Default I/O weirdness
In a PT 9.0.1 session, I can completely delete all I/O paths and rebuild using the "Default" button. Then save, close the session, and reopen only to find this dialog;
http://bit.ly/huc9TP
Why is there an error?
Is anyone else experiencing this?
Old 03-07-2011, 08:01 AM
DigiTechSupt's Avatar
Default Re: I/O weirdness
If you save the report - what does it say? In the report, I mean...
Avid Audio Tech Support
Support FAQ
Old 03-07-2011, 09:11 AM
HD2 HD2 is offline
Chances are you had some inputs or outputs that were called something different in the session than what the defaults are now called.
Check all the inputs and outputs in the session and anything that is grayed out will need to be changed.
For some reason if you change it to NO INPUT and save the session, when you re-open it will be back to what it was and you will get the same dialog box, but if you change it to another input name and save, it will be OK.
Old 03-07-2011, 11:25 AM
You seem to have hit the nail on the head here.
I get the report dialog when I have inputs saved to "No Input" but I don't get the report when I set all inputs to an existing input name.
I'll call this a bug until I'm able to set my inputs to "No Input".
Thanks to HD2!
Old 03-07-2011, 11:28 AM
The current session I'm dealing with gives me this result (see bottom of message). As you will see in this thread, User: HD2 has given me some very useful advice and explained this example.
I have seen different looking reports on other sessions and I will post to this thread as they come up again.
Notes
Missing Stems
The input path "1-2" was made inactive because its stem is missing.
Old 03-07-2011, 11:40 AM
Bill Denton Bill Denton is offline
You might find Page 94 of the Pro Tools Reference Guide somewhat illuminating...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 03-07-2011, 12:27 PM
I didn't find it particularly illuminating; I don't see any difference whether I use "Sessions Overwrite Current I/O Setup" or not.
I still have the dialog when opening a freshly purged/recreated I/O if I have any of the inputs set to "No Input"
Old 03-07-2011, 01:19 PM
formfunction formfunction is offline
But if you answer DTS's question, he might also be able to help you, and in turn help us. ff
Old 03-07-2011, 01:35 PM
I did answer his question. Please see the bottom of the post for the text from the report. The block of text begins with many dashes and continues to the bottom of the post.
Here it is again for clarification;
Notes
Missing Stems
Old 03-07-2011, 02:48 PM
Notes
Missing Stems
Yes you did. Sorry bout that. ff
10.3 weirdness Cryos Pro Tools 10 5 10-01-2012 07:38 PM
E.R. weirdness. guitaramundo Eleven Rack 2 09-16-2012 01:40 PM
More Weirdness OddsAre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-04-2008 03:03 PM
ADC weirdness Muzoid Pro Tools TDM Systems (Mac) 5 11-18-2008 06:19 PM
7.3 Weirdness mattshort 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-16-2007 05:48 AM
