I/O weirdness
In a PT 9.0.1 session, I can completely delete all I/O paths and rebuild using the "Default" button. Then save, close the session, and reopen only to find this dialog;
http://bit.ly/huc9TP Why is there an error? Is anyone else experiencing this? |
Re: I/O weirdness
If you save the report - what does it say? In the report, I mean...
Re: I/O weirdness
Chances are you had some inputs or outputs that were called something different in the session than what the defaults are now called.
Check all the inputs and outputs in the session and anything that is grayed out will need to be changed. For some reason if you change it to NO INPUT and save the session, when you re-open it will be back to what it was and you will get the same dialog box, but if you change it to another input name and save, it will be OK. |
Re: I/O weirdness
I get the report dialog when I have inputs saved to "No Input" but I don't get the report when I set all inputs to an existing input name. I'll call this a bug until I'm able to set my inputs to "No Input". Thanks to HD2! |
Re: I/O weirdness
I have seen different looking reports on other sessions and I will post to this thread as they come up again. -------------------------------------------------------------------------------- Notes -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Missing Stems -------------------------------------------------------------------------------- The input path "1-2" was made inactive because its stem is missing. |
Re: I/O weirdness
You might find Page 94 of the Pro Tools Reference Guide somewhat illuminating...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Re: I/O weirdness
I still have the dialog when opening a freshly purged/recreated I/O if I have any of the inputs set to "No Input" |
Re: I/O weirdness
But if you answer DTS's question, he might also be able to help you, and in turn help us. ff
Re: I/O weirdness
Here it is again for clarification; -------------------------------------------------------------------------------- Notes -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Missing Stems -------------------------------------------------------------------------------- The input path "1-2" was made inactive because its stem is missing. |
Re: I/O weirdness
10.3 weirdness | Cryos | Pro Tools 10 | 5 | 10-01-2012 07:38 PM |
E.R. weirdness. | guitaramundo | Eleven Rack | 2 | 09-16-2012 01:40 PM |
More Weirdness | OddsAre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-04-2008 03:03 PM |
ADC weirdness | Muzoid | Pro Tools TDM Systems (Mac) | 5 | 11-18-2008 06:19 PM |
7.3 Weirdness | mattshort | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-16-2007 05:48 AM |
