Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 02-12-2021, 06:48 AM
Talisker Talisker is offline
Default Little Master Meter is not working
Not a big deal after all, but every once in a while the litte master meter next to the record button isn't showing any level. Definetely my fault but I can't figure out why. ???
Mac Mini 205 Ghz Intel Core i5, 16 GB Ram, OSX 10.8.5, OSX 10.15.7,Focusrite Saffire Pro 40,Behringer ADA 8200 Pro Tools 10.8.5.,Pro Tools 2020, 2xGlyph hard drive 750GB
Old 02-12-2021, 11:38 AM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Default Re: Little Master Meter is not working
If you talk about the Output Meter component on the Edit Window Toolbar, did you check its Path?
When you right-click on the meter, a popup menu opens with a menu item at the bottom "Output Meter Path". You can set it to any of the available Output or Bus Paths.
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 02-12-2021, 01:05 PM
It works most of the time, so that seems to be ok. I has to do with recording on my master print track....
Mono channel meter level lower than Master’s meter level Armando Pro Tools TDM Systems (Mac) 3 07-07-2019 04:51 PM
TL Master Meter Not Working taylor4814 Windows 3 12-20-2012 04:05 PM
Master meter? Tyderian Pro Tools 9 1 04-04-2012 01:07 PM
5.1 master, meter is LCR only? (PT's8) TCDet Post - Surround - Video 0 05-27-2009 08:04 PM
Master Meter clips Siegfried Meier Pro Tools TDM Systems (Mac) 7 05-29-2008 07:02 AM
