Old 12-26-2020, 04:27 AM
Talisker Talisker is offline
Default PT on two screens
Just got PT 2020 after many years with PT 10. So I got a lot of little issues. One is this : I am using two screens an when I saved a session in PT 10 with one edit window screen and one mix window screen, it came up like that when I opened it the next time. PT 2020 doesn't do that yet....what am I doing wrong ?
thanx in advance.
Mac Mini 205 Ghz Intel Core i5, 16 GB Ram, OSX 10.8.5, OSX 10.15.7,Focusrite Saffire Pro 40,Behringer ADA 8200 Pro Tools 10.8.5.,Pro Tools 2020, 2xGlyph hard drive 750GB
Old 12-26-2020, 05:23 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: PT on two screens
Have you extended the main PT window accross both screens? You should still be able to set up your windows in this way. There shouldn't be any change in the process.
Joel
Jam Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 2021 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 10 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 12-26-2020, 05:40 AM
I have an edit and a mix window...what is the main window ? Sorry, if this is a silly question.
Old 12-26-2020, 07:30 AM
Since the OP is on a Mac, this might not be the issue(us Windows users deal with some less-than-friendly graphics limitations)
Old 01-04-2021, 06:23 AM
Really...nobody can help ? If old PT 10 sessions opened in PT 2020 are immediately set up for two screens like intended so the needed information even translates to PT 2020 and new sessions are not, which is the bit of information that is missing in the new sessions ?
Old 01-04-2021, 06:36 AM
crizdee's Avatar
crizdee crizdee is offline
so you have mix on one screen and the edit window on another screen. but on 2020 when you open the session they are both on the same monitor and not on separate monitors. and if you then correct this by placing them on separate monitors it doesn't stick when you re-open the session?
What if you save it as a windows configuration? does it then recall it correct?
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-04-2021, 07:01 AM
Lynn Gräber Lynn Gräber is offline
Right click on the PT icon on your dock and set it to "all desktops".
Old 01-04-2021, 08:13 AM
paul_g's Avatar
paul_g paul_g is online now
I don't understand the question. I have sessions done that were started on 9.x, and 10.3 that were on a 15 year old iMac with a second very old monitor. That computer and monitor are long gone. Just got a brand new iMac and new LG 27" IPS screen. Opened them up, and yes, the two windows were in the same window. Once I arranged everything and "saved", they now open up perfectly fine.
No functionality between older versions and newer versions regarding screen layout has changed
5K Retina 27" (2020) iMac OS 11.3.1 Big Sur
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2021.3.1
EuCon 2020.11.10
UA Luna 1.1.8
UAD 9.13.1
UA Apollo Twin X
Avid S1 / Fire10
HX Edit 3.10
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Old 01-04-2021, 08:35 AM
@crizdee: no, again: the old sessions from the old PT work perfectly in 2020 with Edit and Mix on seperate screen.
But if I make a new session in 2020 it always comes up on one screen. So the old sessions must have a bit of information that the new ones don't have. And no, window confiig also does not work.
@ Lynn Gräber...thanx for the hint, didn't work, either.
@ Paul G read the above maybe then you'll understand. I have no problem with old sessions I have a problem with sessions, I create now in 2020......got it ??
Old 01-04-2021, 10:30 AM
crizdee's Avatar
Are you opening new sessions from a template or just booting up pro tools from default?
If you save a new session as template then use that to start new sessions does it stick?
Chris
Producer, Engineer,
www.ukmastering.com
When using two screens... Samba macOS 1 08-09-2020 08:16 PM
Using 2 Screens Rob2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-29-2009 08:19 AM
Is it possible to run 3 screens on a g5? Premo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-26-2008 03:24 PM
No Help Screens in 7.3.1 510man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-24-2007 11:29 PM
using 2 screens in PT - how do you do it? propofol Tips & Tricks 6 02-16-2007 09:33 PM
