Question about short cuts...
not all of my short cuts work. I'm not sure why. For example; Ctrl+U=Strip Scilence (this works), short cut for "show session setup" (doesn't work). Is this a limitation of the LE system? Many other short cuts work as well as many don't. thanks
Re: Question about short cuts...
Check your Num Lock status.. and if you have command focus enabled. Which language do you have your OS/keyboard set for?
Rail
num lock status is good. English I'm pretty sure. Where do I find command focus? Didn't see it in PT Prefrences. Also the only key commands that don't work are...show transport
show session setup show big counter show automation enable show memory locations. when I try them they change some of the functions in the tool bar. thanks. allan |
command focus is the little button at the top ledt in the edit window next to the Timeline/Edit toggle. It is a box with A...Z in it. This saves you from having to press a modifier when using shortcuts so you just press a single letter.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
You're not meant to use the numbers on the top of the keyboard.. use the Number Keypad.
Rail
sweet. the num lock has to be on. thanks for the help guys!
Short cuts | bonzerboy | General Discussion | 2 | 01-01-2012 02:56 PM |
Your best top 3 short cuts? | starburst | Pro Tools TDM Systems (Mac) | 56 | 08-17-2010 08:36 AM |
Custom Short Cuts on OSX | Ayush Ahuja | Post - Surround - Video | 10 | 01-21-2010 10:52 AM |
keyboard short cuts | sid5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-19-2006 12:15 PM |
short cuts? | jonathan plum | Pro Tools TDM Systems (Mac) | 2 | 08-09-2000 01:43 AM |
