Old 06-15-2022, 06:22 AM
martthie_08 martthie_08 is offline
Default 2022.5: Apple-Z is now Apple-Y
My ProTools software is set to English but I am using a German keyboard (and matching keyboard layout in MacOS).
Since the latest update to 2022.5 the shortcut for undo is now cmd-y instead of cmd-z - that makes zero sense?!
I would have set a custom keyboard command in System Preferences, but as the undo function is context sensitive to whatever the last command was, this will not work. Any thoughts?
Old 06-15-2022, 06:52 AM
Default Re: 2022.5: Apple-Z is now Apple-Y
The newest release allows for customizing shortcuts, so you should be able to remap.
Old 06-15-2022, 06:58 AM
Oh no, gone are the days where I can walk into any studio and just shortcut away without having to think twice!
Anyways, thank you so much for the heads up, that did the trick.
Now on to remove that pesky "z" shortcut...
Old 06-15-2022, 10:35 AM
The Weed's Avatar
The Weed The Weed is offline
You can import and export your custom shortcuts, so any studio with 2022.4 or later you can export theirs, import yours and then, when you're finished import theirs back.
I'm on Windows and the Undo remains Ctlr Z or just Z in Commands Focus Mode in 2022.5.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 06-15-2022, 10:49 AM
GoButtonGuy GoButtonGuy is offline
I’s not so much being able to customize any settings as it is deviating from a decades old platform standard.
Unless there is some sort of compelling reason it seems to be poor design to change something that established in an arbitrary manner.
What happens in Vegas, we make happen...
Old 06-15-2022, 11:02 AM
JingleDjango JingleDjango is offline
It's hardly arbitrary. Users have been clamoring for this for years. If you prefer the stock shortcuts then nobody is stopping you from using them. If you believe the default Z shortcut has been changed in error they you can submit a support case from your Avid account.
Aux Sends causing high CPU usage PT 2021.6/higher with Apple Silicon [FIXED 2022.5] audiogamble Pro Tools 19 05-31-2022 07:51 PM
2022 PT and M1 Apple Silicon glasswing Pro Tools 11 04-30-2022 05:31 PM
Jan 2022 Apple Security Update bricking display again OAG Avid S1, S3, Dock and Control App 2 01-04-2022 09:46 AM
apple-m "mute region" clash with finder apple-m "minimize" wez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-12-2007 05:19 AM
any wabsite for apple accessories (international)& not apple.com sandman General Discussion 0 04-21-2001 06:46 AM
