Old 07-06-2006, 01:26 PM
ModaRecords ModaRecords is offline
Default Duplicate track and instrument
hi..
I'm trying to program drums .. so I have one plugin instrument on a instrument track and program the kick ( midi). next i want to program the snare on a new track but using the same instrument as the bd..not another instance of it.. how do i do this?
thx in advance..:)
Old 07-06-2006, 02:36 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Duplicate track and instrument
hi..
thx in advance..:)
Create a new midi track and route it to your first instrument. make sure "instrument" is set to view in the "view" menu, under "mix window" select instruments, once instrument view is showing, there you can assign the destination for the midi track.
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-06-2006, 02:47 PM
thx.. i did that but when i mute the original instrument track ( the bd) it mutes the new snare recorded on the new midi track..any ideas? thx as always chris..:)
Old 07-06-2006, 02:56 PM
Shawn Simpson Shawn Simpson is offline
Don't mute the monitor section of instrument track. Mute the 'instrument view' of the track. You'll find that as a view option for the edit and mix windows. I'd say the way you want to work you'd be better off using a stereo aux track to hold the instrument itself. Then you can use midi tracks for each part you want to program for that instrument. Good luck.
Cant Duplicate a Track without Track-Heights going Bananas 25ghosts Pro Tools 9 6 08-28-2012 07:27 AM
Duplicate track lukeyy Pro Tools TDM Systems (Mac) 3 11-08-2010 03:32 PM
Mono Instrument Track VS Stereo Instrument Track mbox2issue Tips & Tricks 8 04-20-2009 04:21 PM
Effects on Aux Track versus Duplicate Audio Track JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-07-2004 12:17 PM
duplicate track with all parameters set possible??? joesn Pro Tools TDM Systems (Mac) 1 12-31-1999 09:05 AM
