Old 05-27-2005, 03:28 PM
ModaRecords ModaRecords is offline
Default cd pq codes
Hi .. Iv have a cd that the distribution plant is insisting they want the PQ codes printed on paper. I did not do session.. just have the cd.. anyone know how I can do this?
thx..:)
Old 05-27-2005, 03:48 PM
Seeee Seeee is offline
Default Re: cd pq codes
extract the files off CD, trim off excessive space, though this may degrade the quality, just make sure it's within the 2 seconds that was added by the cd burning program. assemble the song in peak, and print the session sheet. burn the new master.
Ok, dont listen to me but thats what i would do depending on if i liked the client or not.
Old 05-31-2005, 06:53 PM
no way of doing this in protools? also they want cd as is , so they dont want me to trim..
thx..:)
Old 05-31-2005, 07:12 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
You can also import it into JAM which will PRINT TEXT of the PQ coding.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 05-31-2005, 07:15 PM
lemix's Avatar
lemix lemix is offline
ModaRecords,
AFAIK, PT does'n speak CD frames.
One way to do would be to contact a facility using WaveLab ( PC only.. ) ask them to extract the PMCD master to "Audio Montage" and print out the PQ sheet from there. Done.
Nothing has to be trimmed or altered. Assuming the media is error free.
good luck,
*just an opinion*
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 05-31-2005, 09:48 PM
thx..:)
Put the CD in your CD recording drive, open Toast or Jam, under the "recorder" menu select "Disc Info" (I'm doing this from memory, so it might not be exact, but it's close), and you should get a complete readout of info on the disc.
Hope that helps.
rich
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.14, PT 2021.3 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24, 3xS1/Dock.
Also running a 2013 nMP / HDX / S6
Old 06-01-2005, 08:54 AM
Mark Wheaton Mark Wheaton is offline
which it seems the pressing plant themselves could do. ...
where are codes? Fabulous Getting Started 2 10-16-2013 04:56 AM
Authorization codes bilug 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-10-2012 11:43 PM
Error codes shultzee13 Pro Tools M-Powered (Win) 2 06-13-2009 07:20 PM
P,Q codes. the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-03-2005 11:01 PM
ISRC codes poppy Pro Tools TDM Systems (Mac) 1 04-06-2004 11:07 AM
