Old 02-20-2016, 11:17 PM
Becharax's Avatar
Becharax Becharax is offline
Default Mac Pro Late 2013 Freeze Unfreeze
Hello Guys,
I have read all around the net about people having the same problem as mine, the spinning ball that won't stop whereas you can't force quit an application and the music still plays in the background ... bottom line: the mac freezed ! and usually nothing would make it work again other than the power button ...
However, I found a little fix which is whenever I am faced with this issue, if I unplug then replug my apple thunderbolt display then the mac unfreezes and I loose nothing of my work and works like a charm ...
Anyone faced this ??
This is a turnaround but I would definitely fancy a permanent solution ....
Anyone has got an answer for this or faced this ??
Could it be a hardware or software problem ??
Best
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 02-21-2016, 05:16 AM
Default Re: Mac Pro Late 2013 Freeze Unfreeze
DJ:
Once again this sounds like you may have Thunderbolt routing problems. I know in threads passed I mentioned that you may want to try different routing chains to see what works. Have you done that then and have you tried that with this problem? It's almost like there's something systemic going on with your setup that may well be Thunderbolt chain issues (that's assuming your Thunderbolt ports themselves are okay).
Old 02-22-2016, 01:41 AM
Becharax's Avatar
I am still trying musicman ... its a maze ... i have my apple thunderbolt display to which is hooked 3 usb devices and 1 thunderbolt hard drive and I have the thunderbolt sound card hooked to another thunderbolt port ... so basically two thunderbolt ports on my mac pro with 6 total ports .. any ideas ? the best ports to hook it up to ?
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 02-22-2016, 05:32 AM
Like I said before - you have to try various combinations to see what works in your case. There's no one right configuration that will work across all possible hardware setups.
Old 02-22-2016, 06:57 AM
Becharax's Avatar
I wish thunderbolt was never made man ... USB 3.0 is so fast when you plug USB 3.0 SSDs and hassle free ... not to mention that the thunderbolt ports on the mac are easily detachable if u move the cable a little bit the cable will be out of the port easily ...
Crap ....
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 02-22-2016, 08:12 AM
Crap ....
Never had a problem with the Thunderbolt cables detaching themselves but then again I have everything bundled/cabled/tied so cables and connections are secure.
Old 02-22-2016, 08:58 AM
Becharax's Avatar
not detaching themselves .... but they can be loose ... unlike USB ports
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 02-23-2016, 07:46 AM
Never had that happen in either case. Makes a good case for cabling things together which adds security for the connections.
Old 02-23-2016, 11:08 PM
Becharax's Avatar
I heard the new mac pro will have additional usb ports :)
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Mac Pro Late 2013 and GPU Freezes Becharax General Discussion 42 11-30-2015 05:42 AM
Anyone using the Late 2013 Quad-Core Mac Pro? Jcalla macOS 18 08-22-2015 02:07 PM
PT 11 and Late 2013 MacBook Pro 15.4 Ret' garymmadison macOS 6 12-16-2014 05:29 PM
Cracking sound with late-2013 MBP Undertones macOS 9 11-11-2013 09:59 AM
PT 11 - Freeze/Unfreeze/Freeze mbahnmil Pro Tools 11 4 09-10-2013 06:57 PM
