#6561
Re: i7 Builds - Specs and Results
okay interesting, seems there is still hope. I found in another thread that you can play system audio and pro tools at the same time in Windows. The key is you need an interface with a multi-client ASIO driver. Here is the thread if anyone is interested (see ChuckS replies, he uses komplete Audio 6):
http://duc.avid.com/showthread.php?t=391251&page=2 |
#6562
I am currently researching putting together a new Windows machine for my Pro Tools system,
I am guessing I would put Windows 10 on it. I would be going through a MBox Pro 3 I haven't been in the new tech loop, so any assistance or current builds that are kicking but would be helpful. My budget is between 1500 and 1750 (US). I would be buying a new case and putting everything in there. Thanks! |
#6563
I just finished my build and am installing all my plugs afresh (rainy day)
I went with a Asus Deluxe ii X99 (b/c it's been proven hassle free with PT, X99 and Broadwell CPU's that is.....) PCIE lanes running a higher speeds than other boards. (Some lower priced boards only have 4 and the 4th shares the USB3.1 bandwidth) also it came with a TB header and TB-PCIE card. Onboard M.2 ports (I'm using one currently) Really nice board and I'm using the i7-6850k. Sweet little setup.....no real world experience with it yet, but man this M.2 drive is "LEGIT" MOBO - ASUS CPU INTEL i7-6850k Memory - Corsair DDR4 Old GPU - EVGA GeFORCE GTX 760sc Samsung M.2 - SM961 - 256gb drive Case - View31 - Beautiful Case Updated for the record.
Daniel HDX - PT12.5.1 - HD I/O 16x8x8 Win10-Pro (v1709)- 6 Core i7-6850k - ASUS X99 Deluxe ii D-Command Main Unit - 'Ole Blue http://www.sknoteaudio.com/ plugins rock and are affordable. Last edited by YYR123; 09-07-2017 at 11:53 AM. |
#6564
That's a pretty cool motherboard. Thanks for the info.
Would you mine sharing what type of memory did you get? 16gb? And are you going with 4 drives? I am guessing you are using a SSD with that M.2 port? (did you also grab a case?) Thanks again for the info. |
#6565
I didn't get the RGB case just the regular case. http://www.thermaltake.com/products-...?id=C_00003012 $100 bucks. And it's got cool glass sides really heavy glass. Nice case Corsair Vengeance 2400ghz DDR4 16gb - i couldn't justify 32gb - Quad channel board. Right now I have 4 drives. I burnt up 3 spinners b/c I used a thermaltake power cable to power up the spinners but I have a Coolermaster power supply- I have never had that happen to me before. Anyway I am restoring my sample drives and backups but plan on getting another drive to back up the backups, but it won't necessarily have to go in the case, I have a USB3 tray for loading and unloading drives. If you don't have it 3 places it's not backed up!!!!
#6566
Dig the case :)
Just wanted to clarify. You burnt up three hard drives? And the reason was because of a thermal take power cable? Was that not the right power cable? (I'm kinda new at builds!) Did you go with any SSD drives? Thanks again for your assistance |
#6567
I put together a parts list for a I7-6800/ASUS X99 Deluxe II.
https://pcpartpicker.com/list/x8CFVY If anybody has experience with that combo, can you take a look and see if it looks good? I am honestly not sure about the video card (I obviously want to go as cheap as possible with it) Also, is there anything else I am missing? |
#6568
You need to get 4 sticks of 4gb to properly use all of the Quad channel rams bandwidth
I don't have experience with that video card. I use the GeForce GTX760 SC. But it will probably work fine. The chipset and CPU combo is more critical to your PC experience Yeah I burnt the HDD's pcb for sure - I don't understand why but I did..... probably a 12v position and HDD's run off 5v
#6569
I'll look your graphics card. Thanks for the suggestion! |
#6570
Is getting this message normal for the mobo/cpu I picked on PC Parts Picker?
Some Intel X99 chipset motherboards may need a BIOS update prior to using Broadwell-E CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions. https://pcpartpicker.com/list/x8CFVY |
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
