Old 08-09-2010, 07:41 AM
komakaze komakaze is offline
Default "reset on stop" changes values in KORE... how to switch off?
Finally figured out a way to get KORE working as an FX under Pro Tools...
But now I'm experiencing a problem with some (MIDI?) stuff: When I hit stop all knobs go to neutral and every channel mutes.
Is there a way to stop this? Thanks so much in advance for an answer...
Old 08-09-2010, 08:42 AM
Slim Shady Slim Shady is offline
Default Re: "reset on stop" changes values in KORE... how to switch off?
You'll probably get more help on this if you ask in the Native Instruments forums since they make KORE.
Old 08-09-2010, 08:52 AM
That's exactly the kind of answer I was waiting for...
No, seriously: It's an issue having to do with the MIDI-handling in Pro Tools and I thought that someome might have had the same issue with KORE or something else and found a PT-based solution.
Plugins on "factory reset" change sound??? lynx lynx macOS 5 04-30-2013 10:19 AM
Those getting "audio tracks stop playback/outputs disable" Questions? crizdee macOS 15 09-25-2012 08:10 AM
Pro Tools "Sttuers" after quick play and stop MichaelRHolloway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-05-2010 01:16 PM
Any Support for "Phase Switch on Audio Channel" Request ? 25ghosts Pro Tools TDM Systems (Mac) 101 12-14-2009 06:31 PM
Is there a mix window "reset" to zero out plugins/ routing? MarkB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-23-2009 09:14 PM
