Old 05-03-2024, 07:49 AM
niviro niviro is offline
Default Delay Compensation issues internal Dolby Atmos Renderer
Whenever I'm trying to bounce a project in Atmos using the internal renderer, it seems that all objects (thus not the bed tracks) are not latency compensated.
Weirdly enough this only occurs in the export as when playing it in the project file, everything seems to be well in sync. When using my Atmos RMU, everything runs in sync as well, but it would be nice not needing the RMU on lighter projects.
Note that I'm rendering in real-time due to outboard gear. Running the project at 96k with a buffer of 1024 as advised and using PT 2024.3.0
Anyone else running into these issues?
Old 08-13-2024, 10:20 AM
jaywharper jaywharper is offline
Default Re: Delay Compensation issues internal Dolby Atmos Renderer
Yes! I discovered last night with a simple test session using the internal renderer, PT Studio 2024.6 on Ventura in Silicon mode, no plugins save a Click. Panning the click in the center with the Center value at 0, there was an audible delay between the L and R. Turning off ADC solved the delay!
I switched to the external renderer and that also seemed to have solved the issue. I haven't bounced anything yet. I might try tonight to see if I can reproduce the issue.
Old 08-13-2024, 10:41 AM
gives's Avatar
gives gives is offline
good to know. I hope they fix it if it's a bug.
G
Composer/Sound Designer/Protools 2024.10.1 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Sonoma 14.7.1, DP 11.3.3, Logic Pro X 11.0.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 08-26-2024, 08:09 PM
So, it's been a hot minute since my last post. I went down the rabbit hole of reinstalling my OS and rebuilding the machine. Opening my original session produced the same delay issues I had before.
I rebuilt a simple Atmos session from scratch to include a click track routed through several OBED busses plus effects. I'm unable to reproduce the delay issue. I've also reopened previous Atmos sessions with the same success. So, I'm suspecting a corrupt session document.
I've also tried Importing Session Data into a clean session and got even weirder funkiness.
I'm back to being happy working with clean sessions.
Interntal Atmos Renderer - Object delay compensation niviro Pro Tools 1 02-11-2024 05:23 AM
Dolby Atmos Internal Renderer Incorrect Playback on Monitors Syncbox Post Pro Tools 3 01-04-2024 07:25 AM
Printing internal Dolby Atmos Renderer christian kuntner Pro Tools 3 12-21-2023 01:36 AM
Pro Tools 2023.12 Internal Dolby Atmos Renderer Questions and Setup Update bolisound Avid Pro Mixing General Discussion 3 12-15-2023 08:51 PM
Major Delay Compensation issues with Dolby Atmos Production Suite Mixchump Post - Surround - Video 5 03-15-2021 02:43 PM
