Old 02-25-2010, 04:49 PM
drvibb drvibb is offline
Default ProTools Crashing every time I close a session
Since upgrading to PT8.0.3, this has been happening.
When closing a session, the application hangs and gives an error that I must Force Quit to get out of...
THe error = "Could not complete the Close Session command because an access violation has occurred."
I have repaired the drive with Disk Utility. All internal drives are "Read & Write" access.
If the application doesn't hang up, then it quits on it's own.
Has anyone else experienced this?
How can I fix this from happening?
Thanks!
Brian
Old 02-25-2010, 05:19 PM
Default Re: ProTools Crashing every time I close a session
I am doing further testing here...
I opened a session.
I didn't change anything.
I closed the session.
The prompt asked me if I want to save or not... I selected Don't Save.
--- and I got the same access violation error.
Brian
Intel Mac Dual Quad 2.8Ghz with 14GB RAM, running OS 10.5.8
ProTools 8.0.3
Old 02-25-2010, 05:45 PM
Drew Mazurek's Avatar
access errors are almost always DigiDatabase related.
Use the Helper App in the Stickies portion above to delete them.
www.drewmazurek.com
Old 02-26-2010, 09:56 AM
Jeffrey Talbot Jeffrey Talbot is offline
And equally important might be some permissions issues....
Most all apps write a lot of stuff back to the drive when quitting.... last sessions opened... last window positions.... preferences... a lot of stuff..
If it can't write to those files for whatever reason, it could easily crash.
As the previous poster said, deleting all prefs should fix it, but you might want to try repairing permissions first....
Old 02-26-2010, 10:45 AM
Sean Russell Sean Russell is offline
Take the advice of the other two threads next to this one-
Reinstall everything from scratch. Pain, yes. Problems, no.
... but does it help the chorus?
Old 02-26-2010, 11:09 AM
crizdee's Avatar
crizdee crizdee is offline
Thanks!
Brian
If its not the database files needing trashing....
Check ALL plugins are up to date and compatible!!
I had Serato Gate cause this for me with 8.0.1
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-26-2010, 10:47 PM
-----> I repaired permissions, I have Read & Write access on all drives, and I deleted prefs with the application above. I still get the same error.
Next I will try taking out all of the plug-ins to see if ti still happens....
Brian
Old 02-27-2010, 06:47 AM
One Track Music One Track Music is offline
Are you using a Canopus box? See above thread.
www.joeldouek.com
"Show me your Pasodoble!"
Old 02-27-2010, 06:25 PM
Hello,
No Canopus box is being used.....
Brian
Old 02-28-2010, 07:08 AM
crizdee's Avatar
Hello,
Brian
Use this app to list your installed plugins and paste the list here!..
http://duc.digidesign.com/showthread.php?t=264830
Chris
Producer, Engineer,
www.ukmastering.com
protools 11.01 close session crashes on load next session eddie lamb Pro Tools 11 2 09-07-2013 02:51 AM
VE Pro crashing ProTools 8 on session close ThpMusic Pro Tools TDM Systems (Mac) 13 09-06-2011 03:31 PM
Protools locks up on session close jackp Pro Tools TDM Systems (Win) 4 06-04-2010 07:36 PM
PT 7.4 cs5 OSx 10.4.11 Protools hangs on session close xxicjoy Pro Tools TDM Systems (Mac) 1 02-25-2009 02:08 PM
pro tools crashing everytime close session crizdee Pro Tools TDM Systems (Mac) 8 10-19-2005 11:28 AM
