Old 03-14-2004, 11:31 AM
kuen00 kuen00 is offline
Default Machine Control and Sony PCM-7040
I would like to ask does anyone has the same problem on laying back audio to DAT...... My problem is the audio on the DAT start 3 and a half frame later than the Protools start time. This problem only happens on my PCM-7040 and it's fine on digibeta DVW-A500.
My Protools setup is
Protools HD 6.2.3
Mac OSX 10.3.2
AVoption XL
PAL 25fps
thanks!!!!
Old 03-15-2004, 03:03 PM
Ryan L. Ryan L. is offline
Default Re: Machine Control and Sony PCM-7040
I was having trouble laying off to the exact same deck model as well. I found that increasing the preroll time solved the problem. I believe Pro Tools machine control defaults to 5 seconds...I increased it to 10 and things worked fine. Also I noticed you're working in PAL. Is your DAT deck set up to record at 25 fps? If you're using a tape that is not striped with 25 fps timecode then that may be the problem....Hope this helps!
Ryan
Old 03-18-2004, 05:01 PM
Tiago Silva Tiago Silva is offline
Well, I'm having this problem without Machine Control at all. If I place a ProTools chasing the 7040 timecode (let's say I had an audio dropout because of TC dropout - don't get me started - and want to punch in) and go in and out of Input Monitor, the ProTools output is 3 and a half frames earlier than what's in the DAT. If I punch, I kill the printmaster (I use this mainly for printmaster overlaps...)
I must have a misplaced setting somewhere (not TC-to-audio delay, thank you, that's correct...).
Is this happening during recording of the original tape? (maybe there's a 3 frame delay between timecode recorded through the TCGen and Digital Input) - But the pops seem to be in their rightful place...
I've scoured the manuals, and when I have time, I'll go through all the options.
A job's not done until it's ready, or the producer is breaking down the studio's door...
HTML code is On
Machine Control setting for Sony XD Cam Eric Seaberg Post - Surround - Video 3 08-19-2011 05:39 PM
Machine Control and Sony IMX MSW-M2000 DarthFader777 Post - Surround - Video 0 11-13-2006 11:24 AM
Layback to Sony dsr 85 with machine control StefB Post - Surround - Video 4 09-07-2003 07:36 PM
Machine Control & Sony Digibeta Charouhas Pro Tools TDM Systems (Mac) 9 05-21-2002 11:16 AM
Sony DigiBeta with machine control ? sonicsam Tips & Tricks 3 03-03-2001 05:51 AM
