Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 06-07-2024, 03:05 PM
eightamrock eightamrock is offline
Default Stacking Carbon and Pre's in the Rack?
Typically I wouldn't stack converters on top of each other in my rack as they get very hot, but both the carbon and carbon pre have active cooling with fans. Is it safe to stack them and not worry about overheating or should I put a 1U space between them?
Your marketing material makes me think I can stack them safely.
Old 06-08-2024, 07:22 AM
tetonica's Avatar
tetonica tetonica is offline
Default Re: Stacking Carbon and Pre's in the Rack?
On my setup I have the Carbon + Carbon Pre (x2) stacked on top of each other. However my rack is open (a desk rack stand from K&M) so there is plenty of air flow. Also I made sure to have a slight gap between each unit (see attached picture). Hope this helps.
Old 06-08-2024, 07:32 AM
Thanks! This does help. I also scoured the manual and only found references to keeping airflow in front of and behind the units. Seems safe to stack. I’m building a new custom desk for my hybrid setup and toying with the idea of adding some exhaust fans to it as well. I designed ventilation for the front side and back, but you can never have too much air flow!
Carbon with 500 rack- bypassing the preamps / connectivity darkwavo Pro Tools | Carbon 23 01-07-2025 07:13 AM
Pro Tools | Carbon & Carbon Pre compatibility with AVID S4 Control Surface [email protected] Pro Tools | Carbon 9 09-14-2023 10:36 AM
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? pm mastering studio Pro Tools | Carbon 0 12-22-2022 01:54 AM
AVID CARBON - the $3999 Eleven Rack replacement BCnSTL Eleven Rack 6 11-13-2020 09:33 AM
Stacking Rack Mounts w/o Mounts. bassmac General Discussion 6 03-17-2001 12:24 AM
