Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 05-06-2024, 11:34 AM
Sparky1 Sparky1 is offline
Default Recommendations For An External Volume Control Solution For My Headphones
Hello.
Seeking recommendations for an external volume control solution for my headphones.
My Carbon setup is situated a bit out of reach for easy volume adjustment.
Considering adding a volume control device between the headphone jack on the Carbon and my headphones, ideally placed on my desktop.
Preferring a solution that maintains sound neutrality.
Any suggestions?
Thanks,
Sparky
Pro Tools 2024.10
Avid Carbon
Presonus Faderport V2
Ventura 13.7.6
Old 05-06-2024, 12:57 PM
tope d's Avatar
tope d tope d is offline
Default Re: Recommendations For An External Volume Control Solution For My Headphones
Originally Posted by Sparky1 View Post
Hello.
Any suggestions?
Thanks,
Sparky
I'm personally considering the Mackie Big Knob (passive), but I'm not sure if it has a talkback function. But if you don't require a talkback, then this should be fine :)
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 05-06-2024, 01:09 PM
fossile's Avatar
fossile fossile is offline
i have the Presonus Station v2 which handle 3 input sources, 3 sets of monitors, 4 sets of headphones, and has the talkback feature. i like it because i can mute, "dim", or set the overall level with the large knob to any of the speakers easily (and it has individual setting for adjusting levels on each speaker output so you can calibrate the levels fairly eassily).
https://legacy.presonus.com/products/Monitor-Station-V2
Glenn
www.runnel.com
www.reverbnation.com/fossile
Old 05-06-2024, 02:21 PM
Hi tope d.
I too was kinda looking at the Mackie unit. I did notice there was no headphone specific output.
Would the solution be to just build an adapter to merge the 2 mono outputs into a female 1/4”?
And I don’t require a talkback function - so would not miss that feature…
Thanks
Sparky
Pro Tools 2024.10
Avid Carbon
Ventura 13.7.6
Old 05-06-2024, 09:56 PM
[email protected] mradlauer@gmail.com is offline
I have a Heritage Audio RAM 2000.
It's got a TON of I/O, SPDIF & BT inputs. 2 HP outs that double as cue's with the proper patch.
Solved a lot of problems for me: Keep my line outputs from Carbon. I personally don't care for the HP/Monitor section in the Carbon, so this bypasses that all together and adds a bunch of extra flexibility.
Old 05-07-2024, 10:34 AM
Top Jimmy's Avatar
Unfortunately no. +4dBU line level will not drive a pair of headphones to any reasonable listening level. You need a headphone amp in there somewhere.
James Cadwallader
Old 05-07-2024, 02:08 PM
I appreciate the clarification Top Jimmy
Thanks
Sparky
Pro Tools 2024.10
Avid Carbon
Ventura 13.7.6
Old 05-07-2024, 04:39 PM
Thanks for this suggestion foccile
I checked out the manual on this unit - but couldn’t determine if the large volume knob also controlled the headphone volume or just the speaker output.
Sparky
Pro Tools 2024.10
Avid Carbon
Ventura 13.7.6
Old 05-07-2024, 04:41 PM
Thanks for this suggestion [email protected] - that’s one nice piece of hardware.
A little out of my league right now - but one day… ya never know…
Sparky
Pro Tools 2024.10
Avid Carbon
Ventura 13.7.6
Low volume through headphones Digi 003 Slim Pickens General Discussion 2 03-06-2018 11:00 PM
How do you control volume fader with external faders???? xcracer41 Pro Tools 10 6 02-08-2013 05:34 AM
C24 Headphones volume? undergroundcubby ICON & C|24 7 05-16-2010 04:27 AM
96io volume and headphones? buckaroo Pro Tools TDM Systems (Mac) 3 02-26-2009 11:44 AM
Headphones recommendations for low bleed? guitar486 General Discussion 7 02-10-2009 09:42 AM
