Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 04-19-2024, 06:05 PM
asounds asounds is offline
Default Access Carbons Outputs 7-8
I finally got a DB25 cable for my outputs, and alternate outputs B (outputs 1-2 on the DB25) and C (outputs 3-4 on the DB25) are working great and are easy to control.
My questions how to get access to outputs 7-8 on the DB25?
When I plug into them I can't get any sound to come out?
Old 04-20-2024, 06:50 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Access Carbons Outputs 7-8
You need to post much more detail on exactly what you are doing system and configuration wise and list your system either in a thread post or list in your signature line in your User Control Panel (see mine below)
That said
I am unclear what you mean by
??? I don't show any "alternate" B or C designations---- The only Alt designations in my Hardware page "Main tab is -- Alt 1 (LINE 1-2) and -- Alt 2 (LINE 3-4)
Are you using multiple sets of stereo monitor speakers ? OR are you doing surround sound
If not, then there is no need to be selecting any Alt config.
Again why access 7-8 and what about 5-6 ????
In other words
Much more specific detail is needed
I say this because if you are not doing surround ? or multiple monitors then there are no Alt configurations involved and access is configured for all 8 DB25 outputs and inputs is on the Hardware Setup page > Line I/O tab ???
My LINE I/O tab looks like this
And my Main tab looks like
System :
Studio - Avid Carbon interface , PT Studio 2024.10.2 Mid 2020 (intel) iMac 27" OS Sequoia 15.4
Mobile - 2021 14 " MBP M1 Pro PT Studio 2024.10 --Sequoia 15.4.1
Enjoy the Journey
.... Kev...
Old 04-20-2024, 01:51 PM
Sorry, I'm talking about the same thing. I just said "B" and "C" because that is what they correspond to on the front of my Carbon interface when selecting them.
To be more specific, sorry I wasn't before, I'm trying to add additional monitors. (Not surround.) So yes 5-6 would be fine.
Thanks for the help!
Pro Tools 2024.3.1 - Apple M1 Max with Sonoma 14.3.1.
Old 05-01-2024, 01:34 PM
Any idea?
Pro Tools 2024.3.1
Old 05-01-2024, 02:32 PM
massivekerry's Avatar
massivekerry massivekerry is offline
Originally Posted by asounds View Post
Any idea?
Pretty sure this is a Read The Manual situation. But my understanding is that Carbon is designed to have only 3 sets of stereo monitors configured to be controlled by the right encoder knob. That's the Main, Alt 1 (outs 3&4), and Alt 2 (outs 5&6). If you want to route or assign outputs 7&8 to anything else in particular, you'll need to set it up with the I/O Setup in Pro Tools.
Manual and Product ages can be found in the 2 sticky posts at the top of this Carbon sub-forum
Kerry Smith
http://apothekerry.com
Pro Tools since '94.
Mac Studio M1 Ultra : 128GB RAM : Sequoia 15.4 : Carbon : PT Ultimate 2024.10.1 : S1 : Metagrid Pro
Old 05-02-2024, 01:16 AM
dominicperry dominicperry is offline
You should have no trouble assigning Outputs 7-8 to a bus if you want to send stuff out - either hardware inserts or duplicating the Main Bus outputs, but it will be full-scale (the volume control won't work on those outputs, so it will be LOUD).
If you want Outputs 7-8 to respond to the volume control, the only way to do it is switch to one of the surround modes - but that means losing individual volume control over MainOuts, Alt 1 (LINE 1-2) and Alt 2 (LINE 3-4). Instead, all outputs will increase and decrease in volume together.
It's not clear what you are trying to do, so hard to advise.
As MassiveKerry points out, you need to use I/O Setup to control complex routing.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Sequoia 15.2, Pro Tools 2024.10.2, Carbon.
Old 05-02-2024, 07:03 AM
K Roche's Avatar
Any idea?
Yes if only one additional set of monitors, why not use either Alt 1-2 or Alt 3-4 ? Additional monitors is what those alt paths are specifically for
Maybe this will help
https://youtu.be/ORlUQubuQD0?feature=shared
System :
Enjoy the Journey
.... Kev...
Old 05-03-2024, 05:51 PM
First thanks everyone for all the responses.
My Main and Alts are all currently used up. It is going to a Spectrum Analyzer and my Dorrough meter.
I can get 5-6 or 7-8 coming out of Pro Tools fine now, I guess I was wondering how to make it come out during normal OSX use?
If that makes sense.
Pro Tools 2024.3.1
Old 05-04-2024, 06:45 AM
K Roche's Avatar
I am not familiar with either the Meter or Analyzer units
So all I can say FYI is I have a set of monitor speakers connected to the main "Monitor" -1/4 output jacks on the back of the Carbon and I can hear 3rd party apps from the computer (like say YouTube) etc. just fine ??
What about switching the Meters and Analyzer to the 5-6 and 7-8 connections instead ?
System :
Enjoy the Journey
.... Kev...
Old 05-04-2024, 07:06 PM
yeah my the main Monitors work fine with Youtube.
And that is exactly what I'm trying trying to do. Just not sure how to get it, feel I am close.
Pro Tools 2024.3.1
using Two Carbons together ? pm mastering studio Pro Tools | Carbon 15 12-16-2023 09:21 AM
Multiple Carbons? SOUNDDECISION Pro Tools | Carbon 3 03-24-2023 09:23 AM
How to route Carbons analogue inputs to ADAT outs Bedlam Sound Pro Tools | Carbon 8 09-02-2021 11:02 AM
Are carbons head amps adjustable from PT FrustratedLiquid Pro Tools | Carbon 19 04-12-2021 05:25 AM
Outputs configured in I/O setup not available to select as track sends/outputs Stuart@YM Pro Tools 12 5 03-21-2016 07:44 AM
