Hell all,
I just found this site and am hoping someone might be able to assist with this one. I have a DIGI 001 and was using the following setup: -PT LE 6.2 -Mac G4 450MHz dual processor -OS X 10.2 -2GB of RAM -2 video cards for dual display -external firwire drive I had no issues with this setup and PT LE, and could easily have 24 audio tracks up and running with a 256 sample setting for low latency. ProTools was rock solid, and I never experienced any crashes. However, because of a new session I'm responsible for that requires the use of DrumCore, I had to upgrade to OS X 10.3 as 10.3 is the earliest OS X version that is compatible with DrumCore. Before upgrading my dual proc 450MHz G4, on the advise of other PT owners, I decided to use a different Mac available to me. The new system is: -ProTools LE 6.4 -G4 1.25GHz single processor -OS X 10.3.4 -2GB RAM -2 video cards for dual display -3 interal Seagate 250GB drives with fast seek times. I was told that the 1.25GHz G4 with its faster PCI bus would be a better choice over the older G4 dual proc 450MHz computer. So I installed OS X 10.3.4, installed PT 6.4, configured all of the system preferences outlined on this board and in all of the ProTools books I can get my hands on to make my PT system run well, and I get the dreaded "Operating System Held Off Interruptsfor Too Long, Increase the hardware buffer size..." even when running NO PLUG-INS. Keep in mind this is a clean install of the OS, followed by the PT LE install, and nothing else. This computer is a dedicated protools rig. This happens even with sessions with as few as 1 track count! I always have the system usage window displayed, and the CPU usage is below 25%, the PCI bus is always around 50%, and the disk is always around %25. When I get this error, the Processor quickly spikes into the read zone. Increasing the hardware buffer size seems to help a bit, but I still get the error often even if I increase it to the max setting. Should I go back to the old 450MHz dual proc G4? Is Protools 6.4 a bigger resource hog than 6.2? Is it the alignment of the planets? Any help would be greatly appreciated. Thanks, Robert |
I would be tempted to update to 10.3.9. I've been using it with an 001, and it works great. You just can't update QuickTime beyond 6.5.2.
I don't know anything about DrumCore though. Is it a plug-in? Sometimes plugs can cause wonky behavior just from being in the folder. I assume you have run all the CS, and plug-in updates for 6.4? |
Hardware buffer error during playback... | DeyBwah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-25-2010 02:39 PM |
Hardware Buffer Error | Piracy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-21-2007 02:41 PM |
quad opteron hardware buffer error | jonathan jetter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-06-2006 01:57 PM |
(-9136) Error Hardware Buffer | 5280Sound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-08-2005 10:41 PM |
Hardware Buffer Error | buddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-29-2000 05:46 PM |
