Strike Edit Window Loop Length Setting Question
I have created a pattern (Verse A) in 4/4 time and I want to trigger a fill that I also created. The trigger should come in at the end of the Verse pattern on the up beat (1 and) and last for beats 2-3-4 and then go right back into Verse A.
When I trigger the fill it doesn't start when I want it to even though I have experimented with the Configuration settings. It also doesn't return to the Verse pattern until it reaches the end of it's loop, 3 beats later. How do I overcome this? I don't know if it's possible to export the pattern for you to review.
Macbook Pro 2.16Ghz, 4 GB RAM, OS X 10.6.8, 1-Maxtor 200G & 1-OWC 80G External Firewire Drive. - Pro Tools 9.0.3 |
Re: Strike Edit Window Loop Length Setting Question
One approach, would be to copy & paste Verse A to a pre-existing 4 measure length by using the Clear Part button.
filosofem
Aaron Mulqueen - 001 HD Native |
Hmmm... I 'll experiment with this.
Thanks.
It's a little backwards finding/loading a pattern length template first, really, pattern length should be user definable and I'm unclear as to why AIR have chosen this route. Maybe it has something to do with the Timeline intregration, Time Signture and Tempo engine in Strike, I don't know, I'm just thinking out aloud.
filosofem
Setting of 'Edit Window Default Length' | critictalk | Tips & Tricks | 1 | 07-30-2013 10:39 PM |
Edit window default length limit - why? | trc229 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 09-21-2009 06:59 PM |
How can i change the song length in the edit window? | Dusty Angel | Pro Tools TDM Systems (Mac) | 1 | 04-16-2009 01:01 AM |
Help with track/song length in Edit Window | jspellos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-07-2008 07:25 AM |
Loop length & meter setting in Strike's Style Edit | bortraws | Virtual Instruments | 11 | 01-09-2007 01:18 PM |
