Old 09-19-2011, 02:08 AM
apits apits is offline
Default Wavelab don't recognize the driver asio from digi 003
Hi evryone,
i wrote you because i have a problem that need to be fixed..and i can't find a solution..
So.. i always used my old digi 001 with mastering programs such as "wavelab" or "Har bal" without any problems.
Now i upgrade my daw with a digi 003 rack + with pt 8.0 le and when i try to use the wavelab playback this pop-up come out:
"Playback could not start successfully.This can be caused by one of the following reasons:
1- your audio card does not support the output sample rate and/or bit resolution.
2- the input of your audio card is also used(eg.record)but with some settings that are not compatible with the output settings(eg. numbers of channels)
3- another running application has already opened the audio output device.
If i go to "preference" in wavelab i can see the ASIO digi design drivers but as DIGI 002.and if i go to "advanced" the program say that can't find any digidesign card in the system.
i downloaded and install ASIO4ALL wich only allow me to use playback with the internal audio card of the pc.
i set as default my Digi 003 as internal pc audio card also.
i've installed MME HELPER and add wavelab.exe from desktop but nothing there's no way ..
If someone can help i'll be thankful..
Old 09-19-2011, 05:23 AM
TCM's Avatar
TCM TCM is offline
Default Re: Wavelab don't recognize the driver asio from digi 003
Originally Posted by apits View Post
Hi evryone,
Do you try to run PT and Wavelab at the same time?
That is not possible!
I PT 8 it is a single client driver AFAIK.
My 002R and Wavelab 7 Elements work.
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 09-19-2011, 06:05 AM
No i don't...
for this reason it's seems to be wired..
i probably think might be an ASIO matter..
but how arrange this?
Old 09-19-2011, 06:06 AM
I run all non-PT audio out the optical port on my mobo, and feed it to the optical input on a Presonus Central Station. When I want Wavelab, I hit a button. No hardware conflicts and it sounds great. (CS is also great for a lot of other reasons)
Old 09-19-2011, 06:23 AM
it's gonna be a good idea! probably i can connected my old digi 001 with PCI and use it just for running wavelab..but i can't have the same plug-in that i have on pt 8. And i don't know if will be compatible..
By the way would like to use the 003 on it..as might be..
Old 09-19-2011, 12:06 PM
Also, FWIW, ASIO4ALL totally trashed my system. As soon as I removed it, everything went back to working well. Another option you can try is, use the onboard audio and run a mini plug to dual quarter inch(TS) cable and feed the onboard audio(for Wavelab) to the AUX inputs on the 003. Hit the Aux to Mon button(or whatever its called) to listen to Wavelab. I ran that way for over a year and the only "issue" was that Wavelab had some background noise from the onboard converters.
Old 09-21-2011, 05:48 AM
Thanks for suggestions! that i will take seriously in consideration..in case i can't be able to fix this...but no one had exactly the same problem with this combination?!
ASIO Driver for WAVELAB??? DWAGS1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-06-2008 12:03 PM
wavelab not playing back over the Digi ASIO Driver audiosweet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-26-2005 05:29 PM
ASIO driver, 001 & WaveLab efernan1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-13-2003 04:35 PM
001 ASIO Driver and Wavelab DaveJDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-04-2003 08:10 AM
Digi001 with ASIO driver on Wavelab 4 Nahvegador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-22-2003 11:14 PM
