Old 03-04-2022, 02:57 AM
noeqplease noeqplease is offline
Location: Lake Arrowhead, CA, USA, Planet Earth, Solar System, Milky Way Galaxy
Default In Nuendo issue with Avid Artist Control not following track
Using Nuendo 11.0.41 (latest version as of this post), and EuCon version 2021.10.1.29 (latest as of this post).
Artist Control latest firmware 1.3.9.0.Mac OSX 11.6.4 Big Sur.
The incorrect behavior is as follows:
When selecting a channel to pan, for example, it does not change channel,it keeps panning the previous channel,and no matter what you select, it permanently is only affecting that channel.
Session is only 4 audio channels and one virtual instrument. Artist Control is stuck controlling only one channels panning, even after selecting a different channel with the Artist Control.
It seems the touchscreen pan control, which is tied to the touch sensitive knobs simply always stays with the one channel.
Crossposting on the Nuendo forum as well.
Thanks for any help.
Nick Sevilla
[email protected]
Old 03-04-2022, 03:14 AM
Default Re: In Nuendo issue with Avid Artist Control not following track
Tried on another test session with more tracks, same result. The touchscreen and touch sensitive knobs only control one channel, and do not control any others.
In this other test session, it only controlled channel 16, but no others.
Touching the assign / select button on the fader section does select the correct channel in Nuendo. But the knobs do not change to the new channel., they stay with channel 16 all the time.
Nick Sevilla
[email protected]
Old 03-04-2022, 03:46 AM
Seems I solved it.
The option for "Attention most recently selected track (legacy)" was unchecked after installing this latest version.
Once I checked it, the touchscreen and control knobs now properly follow the track selection.
PHEW.
Nick Sevilla
[email protected]
Selected track follows designated fader Avid Artist Control Goombot Artist Series 2 11-10-2017 04:51 PM
Avid Artist/Control Issue ducada Artist Series 1 04-07-2017 06:50 PM
2 avid artist mixes and one artist control V2 for sale Brandonx1 Buy & Sell 2 03-21-2016 09:55 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
Is the Pro Tools MP + Fast Track C400 bundle compatible with Avid Artist Control? Focuret Pro Tools M-Powered (Mac) 1 03-04-2012 01:26 AM
