Mbox Out>Outboard Mixer(Tascam m-208)>Mbox in???
Hello All! Thanks for the opportunity to join this community, hope to be helpful in addition to receiving assistance!
Just purchased the MBox 2 Pro and a Tascam M-208 as an external mixer. I want to determine the best way to route audio out of my MBox, go through the Tascam mioxer and back in. The exact specific of wires is not where my grasp of the concept falls shorts. it's just I want to essentially use my software based programs (ie. a note/sample from FL Studio) to run out of the MBOX (acting as a soundcard) , go through the tascam to "get warm" then come back in for recording. Is this possible? If so, what is the best way? Let me know if that's not clear, and I can explain further. Can/should I have my existing soundcard be a line out, to the mixer, then back into mbox? Or, can you assign one of the line out from the mbox through the FL interface and then assign a pro tools channel to receive that (after going through the mixer)? Any thoughts, similar setups? If not needed to be answered here, please re-direct me to a proper thread! Thanks all! |
Re: Mbox Out>Outboard Mixer(Tascam m-208)>Mbox in???
Welcome to the DUC. What you are attempting is not really feasible with the Mbox, and not worth doing with LE anyway(my opinion as a 6 year Pro Tooler and engineer of over 25 years). If you really feel the need to "warm up" the signal somewhere, I would buy The Massey Tape Head plugin. Go here: http://www.masseyplugins.com/ and download the free demo and give it a try. Its not expensive(a lot cheaper than any mixer worth a hoot) and it will save you tons of hassle and hair pulling. You could also use a "character" mic pre on the way in(check out the Golden Age Pre 73).
thanks for the response...
I've used plugins, and eventually may settle that they are the best answer (as I am most familiar with them after all). I just want to try to route the sound out (so as I play individual samples, queued in FL Studio let's say; either out from 1 of the mbox outs or my original soundcard) into tascam mixer, the back to mbox (recorded on PT) you said its not worth doing, but i'd ike to give it a shot. This mixer has a good warmness i'd like to utilize in capturing samples. Just trying to expand my methods of making beats, and integrating analog equipment. If people can offer a method of this routing (multiple suggestions would be great...) Thanks all, hope we can get some good discussion on some methods! |
bump... por favor? thoughts? innovative solutions? confirming what i said below? lol
THANKS! |
The best solution is to buy a better interface like the 002 or 003 as those allow for inserts and can do exactly what you want(within the limits of dealing with the latency). Sending the entire 2mix or some stems out, thru the mixer and recording to a new stereo track renders the latency issue moot. Your new 2mix may not be aligned with the rest of the tracks, but it won't matter then. Just export your new stereo track as a stereo interleaved file.
Using Outboard Fx w/ MBox 2 | adam79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-03-2012 10:43 PM |
outboard pre with mbox 2 | halfguard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-10-2007 10:40 PM |
mbox,mbox pro or 002 for digital outboard routing? | dcrann11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-04-2007 10:46 AM |
An MBox, a mixer and outboard reverb | B. Earnest | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 05-05-2006 05:41 PM |
outboard mixer or preamp with MBOX | robert-l | Tips & Tricks | 17 | 07-12-2004 01:58 PM |
