Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 12-17-2021, 10:00 PM
Mikey MTC Mikey MTC is offline
Default Alternative AVB options
I've read the requirements and the need for two cascading dongles .... (so Apple don't make a dedicated TB3 > Ethernet adaptor?)
I wa strongly considering getting CalDigit TS3 Plus for general hub duties, multiple monitors, etc.
CalDigit specs now claim that they support AVB with this device. I know Avid have said some other devices claiming to "support" AVB don't perform to their expectations, but this would simplify things nicely if it worked.
Old 12-18-2021, 03:33 AM
dominicperry dominicperry is offline
Default Re: Alternative AVB options
Where does it say this? It's not on their website, in the FAQ or in the manual, nor is it mentioned in any of the three firmware updates on their website.
Dominic
Old 12-18-2021, 02:42 PM
LukeHoward LukeHoward is offline
Dominic
https://www.caldigit.com/connect-10-g/
Edit: whoops, that's not the hub.
https://lukehoward.com/
Old 12-18-2021, 03:38 PM
Sorry - some skewed Google results mislead me.
When searching explicitly for this info, I got a result that said:
"... that's why our CalDigit TS3 Plus dock station will boost connectivity ... it also features Audio Video Bridging (AVB) which means that the ..."
But more careful inspection shows that the first set of dots jumps the discussion into a different product! Doh - my bad!
Old 01-24-2022, 08:00 AM
martthie_08 martthie_08 is offline
are there any news regarding AVB compatible ethernet adapters?
I am looking to buy a new multi-port hub for a Macbook Pro in the studio and it would be very elegant to have an all-in-one solution!
thanks
Old 01-24-2022, 11:21 AM
Not this one, as you will see from one of the questions on the site from some suspicious dude called Dominic..
https://satechi.net/products/pro-hub...s&ref=yotpo_46
Old 01-24-2022, 11:44 AM
thanks Dominic,
I've been eyeballing this one:
https://www.belkin.com/de/support-ar...icleNum=316596
trying to find out what chipset they use for ethernet...
Old 01-24-2022, 12:24 PM
When new hubs pop up on MacRumors I always look around the vendors website and ask the question. Satechi are the first to reply (and it took about a month).
I don't hold out much hope. And anyway, Avid have tested a number of alternatives and only support inbuild Mac Ethernet or the double-dongle TB3->TB2 + TB2 -> Ethernet, so if you have a problem, the first thing that will be suggested is to try one of those.
Dominic
Old 01-24-2022, 12:27 PM
discussed a while back...........
https://duc.avid.com/showthread.php?t=415274
and
https://duc.avid.com/showthread.php?t=415432
Old 01-24-2022, 01:27 PM
not sure if your post was directed at me, but yes indeed, the double-dongle TB3->TB2 + TB2 -> Ethernet is what I am working with at the moment.
Looks like it will stay that way, even when I get a flashy thunderbolt dock.
N key alternative? khaotic intent Pro Tools 12 18 04-18-2016 08:33 AM
UK repairs. Alternative options? Ru_C Pro Tools TDM Systems (Mac) 2 09-15-2008 02:35 PM
OT: alternative to DVD SP? Arno Peeters Post - Surround - Video 1 04-06-2006 09:30 AM
PAZ alternative? propower Pro Tools TDM Systems (Mac) 11 01-20-2006 08:27 AM
Alternative to the VIA? aspect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-02-2001 12:38 AM
