Old 01-21-2025, 05:09 AM
Default Bug or feature?: Can't export basic folder as session
is this a bug or intended?
I can export a routing folder as session via Export Selected Track as session but when trying to do this with a basic folder that option is greyed out.
So after having imported some track markers to a basic folder via session import it becomes impossible to export just that track alone as a session unless you do all sorts of work-arounds like moving all those markers to a routing folder or regular audio track.
Is this a wanted behavior or a bug?
Thanks!
PTHDnPCIe 2024.10.2 (OSX14.7.2), 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 01-21-2025, 05:46 AM
its2loud its2loud is offline
Default Re: Bug or feature?: Can't export basic folder as session
Originally Posted by Frank Kruse View Post
Thanks!
Do you have any tracks in the basic folder? A routing folder is essentially a rebranded Aux Track so it makes sense this would work as described. A Basic Folder is not any particular type of track. It’s just a container of sorts, so it might be by design.
However, This is an unusual workflow so it’s possible it’s a bug.
If you put just a blank audio track inside the basic folder, does it export then?
Old 01-21-2025, 07:33 AM
No. But you can export it when you manually select the containing audio tracks with the folder track. It won't export when closed or just the folder selected when open.
Seems like a bug or oversight to me or AVID doesn't consider basic folders as tracks even though you can put track markers on them.
Old 01-21-2025, 10:00 AM
It does seem like an oversight but could also be by design since by selecting the folder alone, it wouldn't know which tracks within the folder to select. Would either be all or none. However, the fact that you can add markers to the basic folder track would make it seem that those could be exported as a session if needed. But in a workaround, you can just select one track contained in the folder as a session with markers included in the session and on import the markers can be selected for the folder.
Old 01-21-2025, 10:55 AM
I suspect an oversight but it seems a functional bug to me. Maybe open a support case. I can see cases like wanting to map out and share a song structure where this would be handy, I have never thought of trying it.
For users of Intro especially: (non routed) folders don't count in the product track limits and so this may be useful/flexible there for sharing markers. (A digression, but separately I am thinking about a bunch of issues with Pro Tools handling of track limits).
Old 01-21-2025, 11:03 AM
Yeah these are basic folders that PT creates when you import markers to basic folder via session data import in the marker tab. I want to re-share them to team members as a stand-alone track in a session. I guess I'll have to do the old, close session, create new empty session, import that track, save, close, open work session routine that we were all used to before "export selected as session" was born. Or i create a dummy empty audio track inside the folder. Probably faster
Kind of an edge case but just didn't seem logical to me...
Old 01-21-2025, 11:24 AM
Frank,
You can save the folder as a track preset removing the check boxes for everything except Track Markers and then send that off. When the receiver creates a new track with the track preset it will import all the markers.
Feature Request: Export Selected Tracks with Folder Track options real_eyes Pro Tools 0 10-21-2022 01:11 PM
Catalog Feature Request: Export to New Folder NateAlexander Pro Tools 2020 2 12-18-2020 01:02 AM
Export Tracks to Session, Feature Request... JR Fountain Post - Surround - Video 9 09-07-2011 05:23 AM
FEATURE REQUEST: Export Session Data freeBase Pro Tools TDM Systems (Mac) 5 05-22-2009 10:23 AM
Feature Request: Export Selection to New Session chroma17 Pro Tools TDM Systems (Mac) 3 03-14-2007 05:40 PM
