Old 01-21-2025, 04:37 AM
dsalat dsalat is offline
Default Editing Automation
Hi everyone! This is my first post here, and I've tried to search for similar stuff on the forum and youtube, but everything I found is non applicable, so I'd like some insight from pro users to see if what I want to happen is even possible.
I've been on Logic for a while and recently considered moving back to PT, so I did a test project, but I'm having trouble with automation. I like to do stuff with just the mouse, and when editing there's a few behaviours I find inconvenient.
In the example called "Auto A 1", I'd like to move everything up by the same amount (like trim automation would do), instead it ramps up and down ("Auto A 2"). Is there a way to just bump a whole section with edits up?
In the "Auto B 1" example, why is there a new breakpoint (Auto B 2) instead of just bringing the start of the ramp up down with the previous level? I know I can just delete the new node, but it takes one extra step.
Hopefully there are fixes for this stuff. In Logic you can grab and move nodes, lines and sections around and it's quite convenient. I've always heard PT automation is the most advanced, but I'm having trouble getting along with it.
Thanks!
Dani
Old 01-21-2025, 06:12 AM
tope d's Avatar
tope d tope d is offline
Default Re: Editing Automation
you'll need to have a beginning and ending automation point. This can be done by hitting Command+Click on the beginning and ending of the track's automation line. Then you can hit Command+A to select all and nudge it a bit.
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 01-21-2025, 07:53 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by dsalat View Post
... Is there a way to just bump a whole section with edits up?
In the Volume Automation lane, use the Smart Tool to select the section. Adjust as needed.https://www.youtube.com/watch?v=HjoNFBxyXYg
Desktop build: Pro Tools Studio 2024.6 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626
Laptop: Pro Tools Studio 2024.6 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820
Ancient/Legacy (still works!): Pro Tools 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001
Click for audio/video demo
Click for resume
Old 01-21-2025, 10:07 AM
..In the example called "Auto A 1", I'd like to move everything up by the same amount (like trim automation would do), instead it ramps up and down ("Auto A 2"). Is there a way to just bump a whole section with edits up?...
if you want the entire track to be raised or lowered use the trimmer tool at the end past *all* automation breakpoints. If you want to do just a section, go into trim mode and raise/lower the Volume Trim line.
http://www.richbreen.com
Mac Studio / Sonoma, PT Ultimate 2024.10.1. HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Automation playback bug whilst editing automation - is this a deliberate thing? psycho_monkey Pro Tools 1 08-03-2023 11:46 PM
Editing Automation help Jakay Pro Tools 12 0 03-13-2016 10:06 PM
Automation editing help massless Getting Started 2 01-11-2016 01:36 PM
Automation and editing mdb Pro Tools 9 0 12-17-2011 08:08 AM
overall automation editing? req06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-01-2006 05:49 PM
