Downloaded and installed Spectralayers Go today to check out its stem extraction capabilities for some post production. After multiple reboots and installations, it's just not working. After an inordinately long time, the short clip I'm using does show up in the Spectralayers tab, but nothing responds, either in the Spectralayers window or in the Pro Tools timeline. It doesn't crash PT and if I close the Spectralayers tab I can use other functions normally, but as long as that tab is open everything is hosed. What could I be doing wrong?
Update: It does work as a convoluted roundtrip AS plugin, but ARA is a no-go.
Custom i9-12900K, 64GB RAM, W11, PT Ultimate 2024.10.2, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II; MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 Last edited by seanmccoy; 01-20-2025 at 05:16 PM. |
![]() Quote:
You can also try other optimization steps https://avidtech.my.salesforce-sites...oting/en367983
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
No change with 2024.10.2 installed. Report filed.
Also, while the AS version generally works, the external app is frequently crashing.
Custom i9-12900K, 64GB RAM, W11, PT Ultimate 2024.10.2, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II; MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 Last edited by seanmccoy; 01-22-2025 at 12:29 AM. Reason: New Info |
Did you activate and register Spectralayers? Standalone version doesn't work without activation.
Hi seanmccoy,
Which exact OS are you seeing this issue on? Which SpectraLayers Go version do you have installed? If you encounter issues with a standalone SpectraLayers, please consider reaching out to Steinberg support.
Dmytro L Avid Pro Tools Product Management |
Weird, I have used Spectralayers on several computers over the years and never had an issue with getting it going. The only issue is Steinberg's obtuse install and licensing scheme.
Is this on the W11 machine in your sig? I haven't tried it on Windows in a long time.
~Will |
![]() Quote:
But it looks like he has a Mac - running Mojave? Could so old OS cause problems? EDIT: It looks like he has both Windows and Mac. Too small print in his signature to my old eyes:) |
This is the included Spectralayers GO, which doesn't require separate activation.
Custom i9-12900K, 64GB RAM, W11, PT Ultimate 2024.10.2, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II; MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
Windows 11 latest, Spectralayers latest (Spectralayers GO). The main problem is with the integrated ARA version in Pro Tools.
![]() Quote:
Spectralayers Go to Pro Upgrade voucher | Felix Rost | Pro Tools | 5 | 11-22-2024 01:20 PM |
Spectralayers Pro 11 and ARA? | Tim R. | Pro Tools | 7 | 11-20-2024 09:37 AM |
Steinberg spectralayers ara 2 | inspire | Pro Tools | 23 | 11-03-2024 09:44 AM |
ARA SynchroArts Repitch - Steinberg Spectralayers | Arionas | Pro Tools | 2 | 08-27-2023 01:45 PM |
Spectralayers 10 Pro: Separate multiple voices | noiseboyuk | AAX Plug-ins | 3 | 06-23-2023 05:59 PM |
