Getting this often on this project..
- got AAF from MC (guessing at least 2012.12), 3 folders (rendered, unrendered, only rendered). Did SAVE SESSION COPY IN.. and sent that to the sound editors. - they reported getting this error and tracked it down to the ref. audio from the QT, deleted the audio. - ..however, by the time I got it (to mix), the session wouldn't open anymore (with the error message in the subject line, no code). Only way to open it was to make a brand new session and import tracks (linking audio). A few times while working on it (and, of course, during the day of the screening) I had to re-track import again (same error message). I worked 2 days w/o a hitch, then -doing fixes - I was able to open it but ALL the menu items were greyed out+it wouldn't playback. Had to force quit (wouldn't even close the session). That was a new one for me. Did another track import into a fresh session and today I'm getting "automation too dense" messages.. I guess I'm going to do another "save session as" and re-copy all the WAV files to rule out corruption (ran them through Peter Gates' WAV CHECKER, no issues).. Ideas ??? (both times MAC STUDIO, os 14.7.2, PT Ultimate 2024.10.2) |
Try opening a session and simply Import the faulty session's file on the newly created session.
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
![]() Quote:
Worked on it yesterday and this morning getting the same message ("Could not complete your request because basic_string while translating Audio Region List."), nothing will work except yet another Track Import. ..however, I figured I'd CONSOLIDATE instead of linking or copying and got this: "Could not complete your request because Assertion in "../../Cmn/Cmn_Interval.h", line 139." ..so then I made a clean session, track imported and did a COPY FILES. That worked but the Clip List didn't look complete, I saved the session and reopened and got a "Basic_string" message. So something is still weird. ..closed that session, re-opened and getting the same error message as in subject line, so it doesn't seem related to audio files. Last edited by Benny Mouthon; 01-21-2025 at 07:47 AM. |
![]() Quote:
![]() Quote:
As I deal with this, sometimes this opens, sometimes not, can't narrow it down. |
Not track import, im referring to Importing Session’s data.
You should be able to see it under the file tab when on a session. Try importing your faulty session’s data on a newley created session
![]() Quote:
I've already done this about 1/2 dozen times into fresh sessions and still get the issue, I've also LINKED and COPY'd audio, no change. |
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" | EdgarRothermich | Pro Tools 12 | 2 | 10-04-2017 03:18 PM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 01:13 PM |
Region List "Bins" / "Folders" | Styles Bitchly | Pro Tools TDM Systems (Mac) | 1 | 06-18-2010 02:22 PM |
Error: "pro tools session version too new while translating document" | stonerebel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-30-2008 11:25 AM |
"bad data encountered while translating midi chunk list" diigi wizards help!! | jkriske | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-02-2002 01:42 AM |
