  #21
Old 01-13-2025, 07:18 AM
EmilILönneberga EmilILönneberga is offline
Default Re: Warning: Pro Tools 2024.10.2 installer still overwriting izotope
Originally Posted by Daveporter33765 View Post
Has this issue been resolved or is it still a problem?
The title says it's not. 'Pro Tools 2024.10.2 installer still overwriting izotope'
  #22
Old 01-13-2025, 07:40 AM
Daveporter33765 Daveporter33765 is offline
The reason I asked is because we had not previously received the updater in Avid Link before a day ago...after the issue had been reported and Avid stated they were aware of it. So, when it showed up, we thought that a solution had been found and Avid was again pushing the fixed update. We were under the impression that Avid had pulled the updater once they realized it was flawed and that is why we had not seen it in Avid Link earlier.
Luna 1.8, Logic Pro 11.1.2, Cubase Pro 14.0.10, Studio One Pro 7.0.2, Pro Tools Studio 2024.10.1, UAD Software 11.5.2, UA Connect 1.4.20, UA Apollo 8, UA Apollo Twin Mk 2 (2), UAD-2 Thunderbolt Satellite Quad (2), Fractal Axe Fx III Mk. II Turbo FW 27.03, USB FW 1.17 and Axe-Edit III 1.14.07, Studio A: Apple Mac Mini, M4 Pro 14 Core CPU, 64 GB RAM, 1 TB SSD, 20 Core GPU, 1 Gb/s Ethernet, MacOS Sequoia 15.3. Studio B: Apple MacBook Air, M1 10 Core CPU, 16 GB RAM, 1 TB SSD, 8 Core GPU, 1 Gb/s Ethernet, MacOS Sequoia 15.3.
  #23
Old 01-13-2025, 07:52 AM
tope d's Avatar
tope d tope d is offline
Licensing team already reached out to izotope. Team is just waiting for response at the moment. Will update this thread soon.
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
  #24
Old 01-13-2025, 09:27 AM
Thank you for the update; we will refrain from updating until we hear that the issue is resolved.
  #25
Old 01-13-2025, 02:28 PM
Eric Lambert's Avatar
This exact question has been asked 800,000 times in threads across the internet while a bug is current. Perfectly valid. Not only that, it invites Avid to respond about the current state of a fix, which they did (thanks tope!).
  #26
Old 01-13-2025, 04:05 PM
moogboy100 moogboy100 is offline
Originally Posted by James Steele View Post
So it looks to me, if you want to save yourself some time, rather than reinstalling RX-11 with the installer, you could use Time Machine to just restore iZRX11SpectralEditorAAXHook.aaxplugin located in <macintosh hd>/Library/Application Support/Avid/Audio/Plug-Ins/
No the best way to get around this for personal convenience is to pull the iZRX11SpectralEditorAAXHook plugin out of the Audio Plugins folder, then install pro tools, then put the plugin back into the Audio Plugins folder (overwriting the older version Avid installed)
🖥️ Pro Tools Ultimate 2024.10.1 | Mac Studio M1 Max (64 GB) | Ventura 13.7.1 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.10.1 | MacBook Pro M3 Pro (18 GB) | Sequoia 15.1
  #27
Old 01-14-2025, 12:09 AM
Indeed. And if you happen to forget to pull it first (as I did) you will likely have a copy of the pre-installation version of the plugin on your backup drive.
Though I'd still feel more comfortable using the installer since I don't know precisely all that was removed or changed during the update.
  #28
Old 01-15-2025, 04:34 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Please never respond to me in any way again. I don’t want to argue with you here because this is not the appropriate place to do so and because it would not serve any purpose.
Just put him on your ignore list like I did.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 15.1, PT2024.10, HDX, S1/Dock
M1 PRO MacBook Pro OS 15.1, PT2024.10, BabyFacePro FS
  #29
Old 01-15-2025, 05:01 AM
Thank you!
  #30
Old 01-15-2025, 05:02 AM
Thank you.
Pro Tools 2024.6 / HD Driver 2024.6 Now Available! tope d Technical Alerts 0 06-20-2024 02:00 PM
GetTrackList command still returns an empty array here - Pro Tools 2024.3/SDK 2024.3 GRT Pro Tools Scripting SDK Toolkit 6 03-19-2024 02:11 PM
Eventide Reverb 2016 Installer WARNING Tobias Eichelberg macOS 0 03-20-2012 01:38 PM
MBox 3 SPDIF Warning also installer Disc 8068 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-30-2010 02:30 PM
Overwriting old region with new Scorpio253 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-18-2008 07:43 PM
