Avid still hasn't sorted out their installer.
The 2024.10.2 installer overwrites the latest version of Izotope RX. After using the Pro Tools installer, you have to re-run the Izotope RX installer. It's crazy that such a simple installer fix (check versions before overwriting file!) is beyond Avid fixing now 3 times. scan after running the 2024.10.2 installer (showing it did it again) ![]() previous post mentioning this issue https://duc.avid.com/showpost.php?p=...&postcount=109 Avid Case : 04882510 last update to me was 12/21/24 with still no progress. (Seriously, Avid, all package installers have options like what to do when there's a newer file. Avid didn't write their own installer. This isn't complicated to fix.)
Pro Tools Ult 2024.10.2, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 14.7.2 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
![]() Quote:
I've updated the case and alerted the licensing team on it.
Seems to be an issue with izotope setting. We'll let you know once we receive updates from IT team. I've already bump it up the team.
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
How do you update that iZotope extension? (I believe it is for ARA).
I got that with the Mac Updater a month ago and when I go to iZotope Product Portal, it says everything is up to date. The Avid Link RX Spectral Editor link still shows that 11.1 is current. I finally just told Mac Updater to ignore this one since I couldn't find a way to update to 11.2
Pro Tools HDX 2024.10.2 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 13.6.7 Noisebox Studios -Utah Recording Studio |
You have to run the Izotope RX installer again. Product Portal doesn't recognize that Avid overwrote its files (because the other main application files are correct.) So just download the installer direct from izotope or do an uninstall/reinstall from Product Portal to fix.
This is why something this simple that Avid broke is so annoying. The RX install takes a while to run in the first place.
Did you guys temporarily pull the 2024.10.2 installer because of this? It's not showing up for me in Avid Link or in my My Products downloads.
M1 Max Mac Studio, 64GB/2TB, macOS 15.3.1, DP 11.33, Pro Tools 2024.10.2, MOTU 828es, MOTU 24Ai, MOTU MIDI Express XT, UAD-2 TB3 Satellite OCTO, Avid S3, Console 1 |
![]() Quote:
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Sequoia 15.2, Pro Tools 2024.10.2, Carbon. |
Yeah, they are just being slow about distributing it. Go to the download center and you can get it before it shows up under your products
![]() Quote:
UPDATE! Oops! Sorry... I was looking for it in the download links of My Products. Found the actual download center and downloading now, although I'm going to have to the the reinstall of RX11 I guess.
For what it's worth, it appears you don't need to do a full blown reinstall of RX11. I have RX11 Advanced. The current version of RX11 is 11.2.0. Below is the list from Plug Info of installed RX11 AAX plugins running the ProTools 2024.10.2 installer. Note that only iZRX11SpectralEditorAAXHook is downgraded to 11.1.0.
![]() I checked and the RX-11 Editor Application was not downgraded after running PT 2024.10.2 installer. I had saved the RX11 11.2.0 installer, so I ran that and afterward, iZRX11SpectralEditorAAXHook was restored to 11.2.0. ![]() So it looks to me, if you want to save yourself some time, rather than reinstalling RX-11 with the installer, you could use Time Machine to just restore iZRX11SpectralEditorAAXHook.aaxplugin located in <macintosh hd>/Library/Application Support/Avid/Audio/Plug-Ins/
Pro Tools 2024.6 / HD Driver 2024.6 Now Available! | tope d | Technical Alerts | 0 | 06-20-2024 02:00 PM |
GetTrackList command still returns an empty array here - Pro Tools 2024.3/SDK 2024.3 | GRT | Pro Tools Scripting SDK Toolkit | 6 | 03-19-2024 02:11 PM |
Eventide Reverb 2016 Installer WARNING | Tobias Eichelberg | macOS | 0 | 03-20-2012 01:38 PM |
MBox 3 SPDIF Warning also installer Disc | 8068 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-30-2010 02:30 PM |
Overwriting old region with new | Scorpio253 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-18-2008 07:43 PM |
