  #31
Old 11-18-2024, 10:52 AM
EddieJones's Avatar
Default Re: Error occured while trying to load the controller personality "EUCON" - Win11
Originally Posted by UP1 View Post
Error occurred while trying to load the controller personality "EUCON".
W11 - no luck here. I have tried complete uninstalls and reboots in the prescribed order and have cleansed the registry of Eucon items.
I have further deleted folders the installer does not remove for Pro Tools and EuCon in 64 bit and x86 folder paths for Avid, Digidesign along with related Program Data, AppData\Local and AppData\Roaming directories.
I used the EUCON_WorkstationUnifiedInstallWindows_2024_10_0_1 9 to uninstall all applications and preferences.
In my case, I get the same error regardless of whether I attempt to enable Eucon before or after a session is loaded.
I have removed Norton 360 and for testing I have Private Firewall Rules in place for Pro Tools, MC Client and Eucon. Disabled my WiFi so only the NIC is connecting to the router, which worked in prior versions but will compare the documented recommendations.
I have run as admin and non-admin - no impact.
I must have some other conflict and so I will try killing other services to see if I can catch something.
Did you try the fix posted earlier? Remove Steinberg Wavelab from the plugins folder.
  #32
Old 11-18-2024, 03:55 PM
EddieJones's Avatar
We have a fix for this:
This adds directions to tell Pro Tools where to find the missing files. It assumes you have Pro Tools installed on the C: Drive. If not change the drive letter for the path line below.
  • Open Start Search and type “env”
  • Select Environment variables button on the advanced tab (towards the bottom right)
  • Highlight "Path" in the System Variables section at the bottom and click Edit
  • Click New in the Edit environment variable UI to add the new path:
  • C:\Program Files\Avid\Pro Tools\Controllers
  • Click OK and OK again. Restart and you should be able to use Wavelab and EUCON
  #33
Old 11-20-2024, 05:38 AM
mdb mdb is offline
Originally Posted by EddieJones View Post
Have you tried uninstalling using the installer and checking both remove all asps and remove all prefs. Reboot and reinstall. This issue is more a windows file version issue than the new release and has been happening on Windows for years. I can guarantee the new EUCON if far better than the old one, so its worth sticking with this. Some have reported both enabling with a session load ed or without.
edit: NOOOT. It worked one time somehow, and after starting PT again just now it DOES NOT work again. Please don't tell me to trouble shoot yet again. It should just work.
previous message:
I can confirm that the S1 is now working again in Windows 10, after removing all preferences and re-installing.
I could not just select an older version to install. There's no revert to old version in Avid Link (which now doesn't load by the way)...
  #34
Old 11-20-2024, 08:56 PM
UP1 UP1 is offline
Thank you so much, Eddie! I can confirm that adding C:\Program Files\Avid\Pro Tools\Controllers to my Environment variable path has allowed for the successful W11 communication between Pro Tools 2024.10.1, EuControl 24.10 and Avid Control on my iPhone. i see what you mean about the new version. Remarkable! Really haps right now! "I feel like break dancing."
All the best,
Peter
Pro Tools Studio 2024.10
MBox Studio
Gigabyte Z690 AORUS ELITE AX DDR4
Processor 12th Gen Intel(R) Core(TM) i9-12900K
Windows 11 Home Version 23H2
10.0.22631 Build 22631
  #35
Old 01-19-2025, 06:55 PM
Skwaidu's Avatar
Skwaidu Skwaidu is offline
Okay, I just updated to a new computer and this started happening again. Frustrating to have to do the song and dance again (and Eucon was already working with PT, but lost it now).
Windows 11 23H2, Intel Core Ultra 9 285K, Asus Hero Z890, 48GB 8400MHz CUDIMM, Corsair RM850x, 10TB of M.2 (Crucial T705 for OS), 22TB of HDD, Noctua NH-D15 G2 and Fractal Design Meshify 2 + RTX 4070 - PT Ultimate 2024.10.2 / DAR 5.3
And Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6
Used to be/ Spare/ old DAR: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAR 5.0
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and Dock + 3x S1
  #36
Old 01-19-2025, 08:30 PM
Skwaidu's Avatar
Working now. I assume it was wavelab - how was this not fixed in PT 2024.10.2?
  #37
Old 01-19-2025, 08:46 PM
EddieJones's Avatar
You have to download the Wavelab update. Steinberg fixed it, but not sure its out yet.
  #38
Old 01-20-2025, 05:45 AM
Skwaidu's Avatar
From the Avid download portal though? I downloaded my installers under a week ago, so probably not fixed yet then.
  #39
Old 01-21-2025, 09:35 AM
EddieJones's Avatar
I did some digging and it will be included in the next PT release. In the meantime, you can try it:
https://1drv.ms/u/s!AowqasI1coADgYDf...wenM4?e=YMXayb
As this is not released yet it's unsupported....but there's very minimal risk as it's been tested here already.
  #40
Old 01-21-2025, 10:11 AM
Skwaidu's Avatar
Okay, thanks!
Please Help: Error occured while trying to load the controller personality "EUCON". taylor4814 Avid S1, S3, Dock and Control App 10 02-25-2022 09:38 AM
Error occured while trying to load the controller personality "MBOX3". tabonik Pro Tools 12 1 02-01-2019 02:04 PM
Pro Tools 2018.1: Error in Controller-Personality "EUCON" ... johab Pro Tools 2018 0 03-02-2018 02:40 PM
PT10/Digi 003 - Error occurred while trying to load the controller personality "003" J-Xile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-14-2015 09:36 PM
Error occured while trying to load the controller personality "HUI" speng 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-26-2009 12:21 PM
