I'm just getting starting in computer recording.
I'm strongly looking at the 001 but would like to be portable and use a laptop. Can a Laptop computer be used and if so. What would the spec need to be. Thanks ------------------ Beltster
Beltster |
Your only chance is to get a Magma PCI expansion box for laptop. I have not seen this to work but people reported successful results. However, laptop drives are usually too slow for recording and playback. However, these expansion boxes have 2 PCI slots and 2nd slot can be used for a SCSI or Firewire adaptor. More info on; http://www.magma.com/ Regards and good luck ------------------ Yavuz AKYAZICI Guitar Player Composer
Yavuz AKYAZICI Guitar Player, Composer http://cdbaby.com/cd/volcano http://volcanojazz.com http://myspace.com/volcanojazz |
If money is no object then consider the new G4 Powerbook which absolutely rocks. Combine this with the Magma PCI chassis and it becomes sort-of portable and very powerful.
By the time you've bought this though; you'd have been able to buy a 19" rackmount PC case and LCD flatscreen monitor which will fit into a small-ish flight case and cost about half that of the Mac option. I have seen this type of rig used for live use and it takes up no more room than a big sampler. Dan
// Disuye Records HK // Loopmusic Productions |
I forgot - check out www.redsubmarine.com which supposedly builds laptops for audio (reviewed in Sound on Sound this month) although I'm a bit suspicious.
Dan
What new laptop/computer will work with Pro Tools 8? ha | sma5jp | Getting Started | 1 | 12-28-2013 03:23 PM |
Laptop computer for Pro tools | travgei | Pro Tools M-Powered (Win) | 8 | 06-12-2011 12:49 PM |
Tech need to run protools on a laptop computer | Amnesiac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-23-2009 09:46 PM |
Control another computer with a laptop? | milesofwire | Pro Tools TDM Systems (Mac) | 3 | 04-04-2008 10:55 PM |
Laptop computer stand for live performances? | benom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-10-2005 04:24 PM |
