Old 09-24-2013, 06:47 AM
Parisstudio Parisstudio is offline
Default Upgraded to 10.3.7 lost PT HD plugins
Don't see any of the Pro Tools TDM factory plugins. Anyone else have this issue?
Thanks
Old 09-24-2013, 08:31 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Upgraded to 10.3.7 lost PT HD plugins
Thanks
Is HD TDM still the audio engine? make sure the audio engine hasn't defaulted to the computer I/O and is running natively.
As long as the HD TDM is still the audio engine and interface the TDM plugins should still be working ok
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-25-2013, 07:13 AM
I checked and its on HD TDM. I can see all my other TDM plugins but not the EQ or co0mpressor from Pro Tools.
Its mainly in the Pref section under mixing, default eq and dynamics where it doesn't show up when it use to until the upgrade.
Oh, and under DSP its missing too but it shows up in native.
Old 09-25-2013, 08:07 AM
This is what it says when I open a session.
The following Plug-ins were converted to Native because a DSP version does not exist.
Old 09-26-2013, 08:48 AM
Anyone? Thanks
Old 09-26-2013, 12:36 PM
matius_uk matius_uk is offline
Have a look in your un-used plugins folder, my eq had been moved to there, giving me that error message
Windows 7 32bit
Protools HD 10.3.3
Reaper 4.32
HD2 Accel
Digi 192
Q6600 unclocked (3 CPU's set in host processors & 99%)
Gigabyte GA-P35-S3G
3 x 1 GB 1066 OCZ Rapture Ram
1 x IDE Hard Drive
1 x SATA Hard Drive
3 x PCI MKI Powercore cards (removed as refuse to play)
3 x UAD-1 PCI (removed as refuse to play)
Command 8
Old 09-26-2013, 12:41 PM
I did and its not in there. Never happened to me before. Strange
Old 09-27-2013, 02:00 PM
No one really?
Old 09-28-2013, 12:33 AM
I'm going back to 10.3.6 as i'm getting random crashes I wasn't getting before.
Windows 7 32bit
Protools HD 10.3.3
Reaper 4.32
HD2 Accel
Digi 192
Gigabyte GA-P35-S3G
1 x IDE Hard Drive
1 x SATA Hard Drive
Command 8
Old 10-10-2013, 11:26 AM
I guess no one has any idea, was hoping someone would before I downgrade back to 10.3.4
Upgraded to 8.0.5, lost some plug-ins PyneBoxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 08-22-2011 10:16 AM
Upgraded and Lost MIDI centuryson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-13-2010 08:55 PM
upgraded to 8.0.4 lost plug ins legacygt777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-28-2010 06:48 PM
upgraded to 7.3 and lost EQ II aempee Pro Tools M-Powered (Mac) 3 09-15-2007 09:27 AM
Upgraded to 7.3 and lost my DV Tool Kit Droog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-21-2006 11:20 AM
