Well i had Pro Tools 7 installed on my PC when it had Xp, and i recently upgraded it to Vista so i had to upgrade to Pro Tools 8 as well..
Im hooked up through my Mbox 2 Now everythings installed and everything, and i can hear audio from my monitors out of just pro tools, but the Digidesign audio driver isnt installed on my computer for sum reason? I cant select it in the Audio Output Drivers menu because its just not there. So if i say click on a song to open in windows media player it says: Quote:
Email: LLoydBanks023@yahoo.com |
There is no Wave driver for Vista yet. Only ASIO.
The Wave driver is for XP only. What was your reason for moving to Vista? XP is better suited for PT. The Wave driver is just one of the reasons.
~ tom thomas Formerly hobotom Pro Tools Ultimate 2022 HDX HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
thanks for the help guys
yet? meaning its in the works? and where does that leave me? So pretty much ill have to wait till it comes out to have ne other sound except for outta pro tools? and i switched becuz my comp wuz full of spyware and what not and I have vista on my laptop so i figured it switch it since i like it alot |
Yes, Digi has stated here a rewrite of the Wave driver is in the works.
If you have an onboard soundcard, you can keep it assigned to system sounds. Many of us here do that anyway... even with XP. |
alright thanks man
How does one set a soundcard to be assigned to system sounds?
Vista Sound Properties.
Set the onboard soundcard as default Windows device. |
Hello all, I am having the same issue as well, my case being that my operating system is Windows XP and not Vista. I previously had Pro Tools 7.3.1 which worked fine but after upgrading to PT 8, there is no audio in any program or windows for matter, the only exception being Pro Tools itself. I've also tried going into the control panel and the digidesign driver is no longer available in hardware drop down list. It's not a major problem, since I am able to use pro tools without any issues, its more a matter of convenience since I can't listen to anything outside of PT 8. Thanks in advance.
Are you trying to listen to non-PT sounds through your digi hardware?
Jon HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!) |
Audio Driver Problem on HP Laptop with Pro Tools 9 | larsmeijer | Windows | 4 | 09-19-2011 03:26 PM |
8.04 MBox 2 Audio Driver problem | Qusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-10-2010 09:52 AM |
Audio Driver problem | adlib311 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-19-2009 01:36 PM |
Audio or Driver problem? | laboya | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-16-2006 08:36 PM |
Upgraded to 10.3.7...Big audio problem!! Help!! | Lofty11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-19-2004 06:23 PM |
