Q re: Rendering Clip Gain
So when you render clip gain, is there no way to get around it rendering the entire file? I have a session with LOTS of edits within the same file, and when I go to render the clip gain, it makes an entire new file out of every edited piece. So next thing you know, I have 75 versions of a 125MB file, all rendered the same amount. For gits and shiggles I tried setting the Default handle length pref down to 0, but as I feared, I think that only affects Audiosuite processing*. Anyone know the scoop here?
* Just trying it again, and maybe changing that default DID do the trick. It SEEMS to now be applying the gain only to the portion in the region/clip. First time I did it after changing the handle pref to 0, it still went and made an entire file's worth. Who knows. Maybe it just needed to be re-saved and opened for it to kick in. And the funny thing is, when I decided to try it the old way by applying the ol' GAIN plugin, I noticed that the same amount of gain applied THERE made for much louder clips than that amount applied via clip gain! |
Re: Q re: Rendering Clip Gain
Okay, so nevermind, I figured it out. Apparently changing that pref DID solve the problem. I just had to close and re-open the session before it took hold, so that's good.
Though it IS still kinda weird that the same amount of gain applied via clip gain is not as loud as applying it via the GAIN plugin. |
AudioSuite Gain/Normalize also on Clip Gain | A-n-d-i | macOS | 0 | 03-13-2014 12:46 PM |
Audio gain not rendering | MarkWorsnop | Pro Tools 10 | 3 | 03-10-2013 02:59 PM |
Clip gain on clip groups: bug or feature? | idris | Post - Surround - Video | 6 | 01-02-2013 10:48 PM |
Audio is out of sync after rendering clip gain | JWalkerPostAudio | Post - Surround - Video | 27 | 09-11-2012 07:55 AM |
Region Clip Indicator after rendering | Steve Marcotte | Pro Tools 9 | 2 | 03-25-2012 09:31 PM |
