Old 02-06-2025, 03:43 PM
univox1 univox1 is offline
Default Routing folder vs. aux
Hello. What is the difference between a routing folder and an aux track? I would use one of these to multi out a plug in like Ez Drummer. Kick on its own aux, snare on it own aux, etc. Should I use a routing folder instead?
Old 02-06-2025, 03:54 PM
Default Re: Routing folder vs. aux
Up to you, there is no deep difference, a routing folder is really just an Aux, it's really if you want the UI cosmetics of a folder. I'm so unhip I just keep reaching for aux's.
Old 02-06-2025, 04:47 PM
Wireline Wireline is offline
Indeed. I’ve not understood the whole folder concept since introduced. Auxes and groups I get…VCAs I get. Everything seems to be the same things in a different wrapper
Ken Morgan
Midland, TX
A Musical Nobody Since 1972
2017 Intel Mac Mini, 32G, PT 2024.6.0 Studio, Presonus Quantum 2626 or 1824C (whichever works) and a bunch of stuff via ADAT
Old 02-06-2025, 10:24 PM
Top Jimmy's Avatar
A common usage can be to put a VI on the routing folder track and put all the MIDI tracks that play the VI in the folder.
James Cadwallader
Old 02-07-2025, 04:16 AM
midnightrambler midnightrambler is offline
Pah! I'm so unhip I'm still refusing to use "Dark" mode
Old 02-07-2025, 06:39 AM
K Roche's Avatar
K Roche K Roche is offline
Functionally there is not much difference.
BUT myself for my workflow all I use now are routing folders with the exception of a 2- Bus aux track ( which I name 2 Mix) which all the folders are routed to Also I always have a parallel reverb Aux track (to send to) and sometimes a parallel Tape Echo/Delay Aux track.
The main reason I use them over Aux tracks being I can collapse/open them right in the mixer window with out having to group them and and do the group hide and unhide thingy .
And with that ability to collapse them I can have my entire session (up to about 20 something tracks) show in the mix window in the wide mixer channels view On my 27" displays
For example here is a screen shot of session with 20 tracks and the all the Routing Folder tracks are collapsed Except the Vocal -(Vox) routing folder is open with the main vox audio track and background vox audio track showing ( magenta)
So I have 5 routing folders each with at least two audio tracks and then the Reverb aux track (M7) and the main sub bus aux track 2 Mix
The other thing I like is the way I have my color pallet set up is the entire audio or instrument tracks and aux tracks show the track color. However the routing folders are showing color only at top and bottom bands and the main body of routing folder the track is dark grey, (which happens automatically) Which makes the folders instantly distinguishable from all the audio instrument and aux tracks
System :
Studio - Avid Carbon interface , PT Studio 2024.10.2 Mid 2020 (intel) iMac 27" OS Sequoia 15.2
Mobile - 2021 14 " MBP M1 Pro PT Studio 2024.10 --Sequoia 15.1
Enjoy the Journey
.... Kev...
Old 02-07-2025, 06:50 AM
K Roche's Avatar
In answer to the OP's question about setting up a multiple out VI like EZ drum
Yes a routing Folder is great for that
Here is a session where you can see (left to right) I have the Acoustic Rhy Gtr folder open ( medium blue routing folder with powder blue audio tracks ) I have the VI routing folder open (Bright Yellow) I have the Vox folder open
AND then I have the Drums routing folder open (dark Brown with lighter brown Instrument and Aux tracks ) I am using Slate SSD5 so it has to go on an instrument track and then the Kick, Snare, etc on their own aux tracks all in the Drums routing folder
And again you can instantly see which are the dark grey routing folders and which are the other types of tracks . Note this session with the Drums added is 29 tracks total
System :
Enjoy the Journey
.... Kev...
Old 02-07-2025, 06:58 AM
ejinbc ejinbc is offline
OP
You are correct in that Folder tracks are mostly just for organization - although I like the idea mentioned above of putting VIs on Routing Folders and the Midi tracks within. I must admit however, that the new track monitoring button and playlists on Instrument tracks have recently changed my workflow. Very useful, and the reason I reinstated my perpetual license.
For me, the one killer feature request I keep making - yup, a broken record - is to have independent views (folder expansion status) in the Mix and Edit windows. I work on a 4 monitor system, and it would be very useful (sometimes) to have all my Aux tracks hidden in a Folder in the Edit view, but visible in the Mix window. YMMV.
Cheers
ejinbc
Old 02-07-2025, 01:24 PM
s.d. finley s.d. finley is offline
For my workflow Routing folders are best for hiding tracks. For example a chorus with 30 tracks of mains and harmonies. After getting the balances and using whatever plugins and sends on the individual tracks I can hide the tracks and just deal with the Routing Folder. This takes up less monitor real estate. I will also do this to other groups of tracks. I like the addition. Auxes I still use for parallel FX such as delay, reverb etc. YMMV.
sdf
www.sugarhillstudios713.com
Old 02-07-2025, 01:25 PM
Electronic1982 Electronic1982 is offline
It was really brought in for additional routing and organisation options.
In the mix window, the folder tracks should really open to the left, not the way if is now (where it they open to the right).
There needs to be an option to set the 'open folder direction' to Left or Right for just the Mix Window in the preferences menu.
This would be a good upgrade to them.
move to new folder -> "routing folder" as default Franklyn Pro Tools 2 12-02-2024 01:07 PM
Folder Routing Thp1973 Tips & Tricks 4 12-09-2022 12:10 PM
Routing Folder Inside Routine Folder - Solo Issue John9281 Pro Tools 3 03-20-2022 10:43 PM
Routing folder+VCA mgoorevich Post - Surround - Video 12 09-30-2020 03:45 PM
Another Folder Track bug: Soloing a Routing Folder doesn't solo routing bus XJENSEN Pro Tools 2020 7 04-24-2020 07:29 AM
