headphone amp
Hello i have a Digi002R and a Behringer POwerplay Ha4700 Headphone AMP. I was wondering how can i connect the amp to the Digi002R? Would i need an external mixer? or would i just use the line/inst outs on the Digi002R?
Re: headphone amp
I think you could even use the master outs on the Digi. Any out will work though as long as the audio is bussed out correctly.
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core 16 GB RAM Mountain Lion 10.8.5/El Capitan 10.11 Focusrite Saffire Pro 40 Ableton Live 10/Presonus Studio 3 |
Re: headphone amp
I have an M-Box 2, so not sure what your set-up looks like, but on my system, I take the two outs from the M-Box and put them into the headphone amp, then from the headphone amp outs to the monitors. I assume your system should be similar.
Dan'o :} |
Re: headphone amp
I used an 002 with 4700, and I did exactly that. Main output (1-2) went to the headphone amp, and the monitor outputs went to my monitor setup. No changes were needed in I/O setup. Slightly different cabling would have allowed me to run separate headphone submixes - I didn't do that.
Quad 2.5 G5, 4.5G RAM |
Re: headphone amp
Ok So if the Main outputs go to my headphone amp, and the mon outputs go to my monitor, how would i get a different headphone mix in the headphone amp? and do the main outputs of the digi002 go into the main ins on the headphone amp?
Re: headphone amp
With the 002r you have 8 analogue outputs. As long as you are not using outputs 3-8 for other external gear, then you can use them for a separate mix. What you would do is go from lets say outputs 3 and 4 to the headphone amps inputs. Now inside of Pro Tools create a send on each of the tracks that you want in the headphone mix to outputs 3 and 4. You would then make them all pre-fader which will allow you to have a separate mix from your monitor output (outputs 1 and 2). Make sure you I/O setup is correct too.
Re: headphone amp
Ok so here's what I got. Analog output 3 on the digi going into aux in on chan1 of my headphone amp. Analog output 4 from digi going into aux in on chan2 of headphone map. And basicaly I would use the direct outs of the headphone amp to plug my monitors in?thanks for all the help so far
Re: headphone amp
Here's another way to do it using an Aux. track in PT to get another headphone mix. Learn from my buffoonery on this thread:
http://duc.digidesign.com/showflat.p...part=1#1187744 ....just make sure to read the last post where I finally get it right.
Re: headphone amp
I changed my setup today and moved cables around . Everything is backup now but I need the correct headphone assemly again for sep mixes. I have sep mixes in all 4 channels of my headphones but I cannt control the vol. Using the main control or from the indv. Mixes. I have headphone out 1 going into the input 5 of digi 002. Headphone is goiingo into input 6 and etc. But yea can someone help me get this straight.
Eleven Rack headphone port versus MBOX and other interface headphone ports | World Spirit | Eleven Rack | 3 | 02-12-2012 11:34 PM |
headphone amp | tuffy21 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-01-2005 11:05 PM |
OT - headphone amp | euphjazz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-16-2005 03:24 PM |
headphone mix | MR808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-19-2003 11:29 PM |
Headphone Impedance and the 001 Headphone amp | Mark_Knecht | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-15-2002 12:22 AM |
