Difficulty Recording Strike Midi Data
Maybe this has been covered before, but I am having trouble recording Strike performance data. I want to play a series of patterns on the Style keyboard and record this MIDI data to the Strike Instrument track. I can draw in pattern triggers by hand, so I know my Strike playback is working. I do not have an extrnal keyboard controller, but I figure I must be able to record my mouse clicks on the Strike keyboard, no? Is there some MIDI routing or MIDI set-up to be done? I am on Protools LE 7.1 with Strike inserted on an Instrument track. The input to this track is "All". In MIDI Preferences, my Default Thru instrument is Strike 1-1.
Thanks much, |
Re: Difficulty Recording Strike Midi Data
Sorry, Strike only supports direct MIDI Input. The Pencil tool or the MIDI Event List is basically your only alternatives within Pro Tools. You might be able to get away with some sort of Virtual MIDI Keyboard (Google).
filosofem
Aaron Mulqueen - 001 HD Native |
Thank you. Are you a digidesign employee are just a helpful user? So if I get a basic keyboard controller can I trigger the Strike patterns and simultaneously record the MIDI data to a new MIDI track?
Problem with recording MIDI data | Fladlien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-10-2005 06:04 AM |
Difficulty w/ LOOP RECording useing MIDI drums... | DVDave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-16-2004 03:04 PM |
recording midi clock data on P/T Mix | jer | Tips & Tricks | 0 | 03-31-2004 02:43 PM |
recording midi clock data on P/T Mix | jer | Pro Tools TDM Systems (Mac) | 0 | 03-27-2004 03:06 PM |
recording midi data | JPMenz | MIDI | 1 | 04-04-2002 04:53 PM |
