Old 06-25-2008, 08:58 AM
Sean L Sean L is offline
Default protools stalls on opening the 7.4.2 the full version
When I open protools it starts to load up but then stops at loading plugins dpm, and it gives me the little clock and the spinning color circle,this seems to last indefinitely whats goin on?
2gb Ram 2.66 ghz quad core
Old 06-25-2008, 09:28 AM
DigiTechSupt's Avatar
Default Re: protools stalls on opening the 7.4.2 the full version
Most likely you need to update your plug-ins, including ReWire applications.
ALL Rewire capable applications must be updated to their most current, Leopard compatible versions, especially Melodyne.
You could also just remove the Melodyne components from MacHD>Library>Application Support>Propellerhead Software/Rewire, which should allow Pro Tools to launch (assuming all other ReWire components are up to date...).
Make sure that all other installed plug-ins are the minimum required for Pro Tools 7.4.2 compatibility:
Pro Tools Leopard Plug-in Updates
Avid Audio Tech Support
Support FAQ
Old 06-25-2008, 09:29 AM
Phil Ogden Phil Ogden is offline
Most likely an incompatible plug-in. Check that any third party (non Digirack) plug-ins are Leopard compatible (I'm assuming you're running Mac OS 10.5.3, right?).
Rewire applications like Melodyne, in particular, seem prone to causing problems if not bang up to date. You can test this by moving plug-ins to the unused folder, clearing prefs/rebooting and putting them back one at a time (launching PT each time also). Do this also with the Digirewire plug-in as this can alleviate the launch failure if, as stated above, Rewire applications are not compatible.
BTW More information should be supplied with your post to enable meaningful advice to be given.
help us help you - what you need to know before posting
http://www.myspace.com/philogg
Old 06-27-2008, 10:38 AM
Now when I download the izotope upgrade for example, it tells me it failed to mount, any ideas...
Old 06-27-2008, 10:43 AM
Slim Shady Slim Shady is offline
Either your internet connection is wonky or the server you're downloading it from is wonky. Try it again in a little while. A failure to mount usually means it didn't get all the data in the download.
Old 06-27-2008, 11:45 AM
cheers, you dont happen to know why my pt le code on the inside of the user guide does not validate,i presume it's something to do with the upgrade i did to 7.4.2, where do I find that code?
Old 06-27-2008, 11:48 AM
Someone else had the same question.
Support FAQ
Old 06-27-2008, 11:52 AM
1. Do you have a version 7.4 code (starts 074)? A 7.3 code (or earlier) will not work.
2. If you purchased 7.4 online, you may be able to retrieve the code from your Digistore account.
3. If you obtained 7.4 as an amnesty upgrade, the code should be available from you My Digi account.
FS: ProTools 10/11 License Bundle - full version DeadAgain Buy & Sell 2 06-30-2013 05:47 AM
ProTools 9/10 Bundle Full Version (Not HD) Nearlymen Buy & Sell 3 04-29-2013 03:54 AM
Protools 10 With Windows 8 (Full Version) auratone Pro Tools 10 11 12-09-2012 06:15 PM
Protools 10 full version vs. Upgrade pieroft macOS 2 12-04-2011 01:37 PM
Can the FULL version of ProTools be used w/ digi001? Mr Scary P4P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-24-2001 07:16 AM
