Setting up new system and having peculiar issues
Back in the audio universe after stepping away for some years.
Setting up a new system using my cheese-grater that ended on PT 2019.6 perpetual. The system is using RME HDPS AES cards, one Mytek 8x192, one Brooklyn DAC. I set up an aggregate in the audio-midi with the Brooklyn and the HDSPe AES card. The first peculiar thing I see is in the I/O routing matrix. Both input and output are giving me odd numbers of options. I am unclear what causes this and how to fix it. The second thing is I am unable to get hardware I/O to work. I have rung out the routing in the I/O and I believe I have it down to something funky with the I/O setup must be causing the hangup. The pictures show the current I/O setup (Input, Output, Bus, Insert), and, one pic of a routing test in an edit window. The routing as I have it in the I/O gets all in I/O to jive in the analog domain. I am monitoring on the Brooklyn DAC so thats easy to tell, and the 8x192 has meters for the 8 channels and can toggle between DAC and ADC. (The 8x192 has the ADC source set to analog as it should be.) When I set a stereo track to output to the Brooklyn DAC - all good. When I insert any of the stereo pairs from the 8x192 - silence. When I create a stereo track and set the input of this new track to the insert on the audio file I have audio (I included a picture to help illustrate this). I know PT is persnickety with how the routing is setup. Can anyone shed some light on this issue? Thanks & very best... Josh |
Re: Setting up new system and having peculiar issues
I do not understand why you are trying to use crappy aggregate I/O.
You have a wonderful RME interface card, wire that to both boxes (RME provides clear instructions on how to wire their AES/EBU to S/PDIF for devices that need S/PDIF). You have 32 x 32 IO on those RME HDSP (HDSPe?) two card pairs. As for I/O mapping... you just sort that out yourself. AES/EBU carries no information about I/O ports. Just work out what you have connected to what AES/EBU I/O on the RME HDSP (HDSPe?) cards and name the Setup>IO>* to match. And you are likely borking yourself with H/W inserts. Get basic stuff working first. But the reason this won't work with what you have done is your aggregate pushes the I/O pairs out of alignment, and since Pro Tools wants matched I/O port numbers for H/W inserts you not would have to use say inputs 2&3 on the 192 with outputs 1&2 on the 192 for a stereo H/W insert. When you set this up properly on the RME HDSP card with no aggregate just do not let the Brooklyn "push" the 192 out of alignment with the RME AES/EBU port numbers. |
Thanks Darryl.
The aggregate setup is not here to stay. I have more converters and cabling coming that will facilitate a final push on this. The aggregate is because I bought an 8x192 and wanted to test it out and figured I should be able to use it via hardware inserts - which was an hours long exercise trying to make sure I was not losing my mind. Brooklyn DAC was already setup via USB. Your comment is very helpful, really, thank you. Will wait til I get the rest of the stuff. Hah....borking... |
Can you tell me why I was getting odd numbers of I/O options in the I/O matrix? Does not make sense to me.
But just don't waste time on this stuff, start doing it properly using the RME card to connect to both devices and stop trying to use aggregate I/O. |
There’s a bug in Pro Tools with aggregate devices where the IO input and output numbering will be offset from actual numbers shown in the AudioMidi setup window of the Mac OS.
No, and its likely not to ever be, which is why Darryl's advice is best followed. Beyond that, what "Hardware" are you dying to use as inserts? I ask because of 2 reasons. 1-just because you CAN doesn't mean you SHOULD(don't waste effort for using cheapo hardware when plugins will do the same or better). And; staying ITB(In The Box) avoids lots of issues. Now I love good hardware as much as anyone, and I use plenty, BUT, I use it on the way in and keep the mix ITB.
Peculiar Mbox 2 output issue | ganderson87 | FireWire & USB Audio Interfaces (Mac) | 1 | 05-20-2014 12:00 PM |
Peculiar little mess! | tchipman | Pro Tools 9 | 8 | 03-12-2013 03:08 PM |
D-Command Peculiar Group Issue | pdqprods | ICON & C|24 | 0 | 01-23-2013 07:11 PM |
Peculiar problem keeping me from editing any sessions | aflooba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-06-2012 06:39 AM |
Peculiar De-essing technique... | DigiDawg | Tips & Tricks | 16 | 06-25-2000 09:14 PM |
